Ignition coil/mass air flow problem {c5}
Old May 4, 2008 | 03:00 PM
blackula 99's Avatar
blackula 99
Default Ignition coil/mass air flow problem {c5}
Ran across a strange problem this morning....Dic through me a po102 code and later in the day a po351.... they break down into mass air flow sensor low frequency and ignition coil #1 circuit problems..... Car just started running rough,acidic odor to it...any ideas on how to fix?Any help would be greatly appreciated.
Old May 7, 2008 | 10:28 PM
blackula 99
Ahh, found the problem with my trusty voltmeter....pinched wired feeds from under the cowl going in ...mystery solved.
