Please help, having a problem with my C5!!
Old May 5, 2008 | 09:33 PM
goinlower6969's Avatar
goinlower6969
2nd Gear
Default Please help, having a problem with my C5!!
Hi, im having a problem with my vett,, wonder if any one can help. The car starts and idels with out a problem,, all electronics, lights, everything works.. As soon as i put it in drive or reverse and give it gas, it shuts the car off..I replaced the battery and tested the alternater and there good to go.. I also replaced the Service column lock as the dash indicated,,,,what else can i do? Please help!!!!
Old May 5, 2008 | 09:37 PM
jedblanks's Avatar
jedblanks
There is a procedure to reset the column lock fuel cutoff on here somewhere. Maybe a search will turn it up?
http://forums.corvetteforum.com/show...l+cutoff+reset
That thread suggests reprogramming the key fob?
Not sure. Didn't have time to read the whole thing, seems like a simiar issue
And make sure you read this sticky all the way through
http://forums.corvetteforum.com/show....php?t=1015483
Old May 5, 2008 | 09:38 PM
97C5owner's Avatar
97C5owner
Mine did the same thing a few years ago. The DIC displayed "pull key 10 sec" I think it misread the chip in the key, because I've had my collum lock serviced as well. Mine just seemed to go away after two times. I had just replaced the battery.
Old May 6, 2008 | 06:26 AM
goinlower6969
2nd Gear
Mine also says pull key and wait 10 seconds,, i tryed that to,, no luck, ive had 2 guys down to help and go threw the dash and no one can figure it out...
Old May 6, 2008 | 07:28 AM
BlackZ06's Avatar
BlackZ06
2 MPH fuel cut-off ..... due to column lock
First thing to do whenever your Corvette has ANY kind of problem .... check for DTC posted in the car's computers. Here is the procedure ....
https://www.corvetteforum.com/techti...D=26&TopicID=1
List all the codes here.
Second, read the sticky at the top of this forum regarding the COLUMN LOCK. Your car will not be driveable until you address this issue ... your PCM will cut off the engine as soon as you reach 2 MPH until this is cleared. The BCM is telling the PCM your column lock is engaged.
Old May 6, 2008 | 07:34 AM
lil vette's Avatar
lil vette
again, with the PCM, BCM, ABC, XYZ, NUTS & BOLTS....
somebodeeeee help meeeee
Old May 6, 2008 | 07:54 AM
dougbfresh's Avatar
dougbfresh
The security system kicked in, that's one of the lame A$$ fixes GM did, they removed the lock plate but kept this feature as "SECURITY"-car will start and die above 2mph. Time for a visit to the dealer then a CLB.
Old May 6, 2008 | 07:58 PM
TLewis4095's Avatar
TLewis4095
Re set you fob.....hold down the lock & unlock buttons until the car beeps, then unlock & try it. Only on earier C5's but we see it quite often.
To Please help, having a problem with my C5!!
