Heads before Cam?
Old May 7, 2008 | 12:03 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default Heads before Cam?
I'm really wanting a H/C swap, but at the time I feel that only one is in the budget. I've seen so many DIY head swaps on here it looks so easy... perhaps somthing I could attempt.
The goal with this car is for a mild street machine. I'm looking at getting LS6 heads and LS6 intake and later on a cam. If I still need more power, I can have the head sand intake ported.
Question: what effect (of any) would i notice by swapping out me OEM LS1 heads for a set of LS6? Is this somthing that can easily be done with basic tools?
thanks.
Old May 7, 2008 | 12:18 AM
tiki240's Avatar
tiki240
IIRC, the heads and intake will net around 50 HP. a nice cam is needed to really take advantage of all that extra flow... have you looked at TSP cams? they are like 350 bux...
Old May 7, 2008 | 12:29 AM
bdiddo's Avatar
bdiddo
I am in a similar situation. I am currently rebuilding a LS1. My research so far indicates that adding LS6 heads (ported) and an LS6 intake would get in the range of 400-415 hp and about 400 torque. Those number seem to make sense since that application is basically a C5 Z06 with ported heads (yielding that extra hp and torque).
I am looking far abit more, which a hope to achieve with some light block work (to raise the compression) and a strong cam to go with the above application. however, i am also looking into PP or AFR (205) heads. Just don;t know if I can swing it but don't won't to second guessing that i left to much on the table.
Old May 7, 2008 | 12:40 AM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
I would really do it all at the same time. You can find used LS6 intakes for $350 all day long, a mild cam (224ish, 230ish) and a set of ported LS6 heads are all pretty reasonable in price.
It definantly would not be worth it to do the swap, then take them back off to have ported. Look into the partiot heads. They seem to do pretty well. Good luck
Im sure many more will chime in where I have forgotten. This is finals week for me and Im not all here right now
Old May 7, 2008 | 12:55 AM
MattB's Avatar
MattB
Heads only was my favorite mod so far, it can be done with basic tools and you don't have to worry about timing. 50 hp out of a ported set of LS6 heads seems a little high, but it was definately more of a kick in the SOP than the LT headers were. And, you retain all the driveability and stealth of the stock cam. A non-ported set of LS-5 heads will not net you much.
I tried a big'ish cam and I'm down grading some, if that does not work then a 224 range is next. Cams are very subjective, best bet is to find someone who has a cam and see if you like the sound and like the power.
Until then heads only is a good starter project for the DIY guys...
If your paying someone, then its not the best way to spend your money as it would double your bill...
Old May 7, 2008 | 02:32 AM
ChipN's Avatar
ChipN
Default I would go with a cam first
You will save money by doing both at once (labor, gaskets, valve springs and retainers, etc.)
I had the same dilemma a few years ago, researched it quite a bit, and then spoke with Phil at DTE for a good 30 minutes. I was also considering supercharging vs. a H/C job.
My decision was to go with a cam, headers, and better air intake first. The results were very good. The next year I added heads (AFR 205) and a Fast 90 intake. The end result is impressive (IMO), but the cam seemed to provide more bang for the buck. BTW, I have a very mild "baby cam" that has a near stock-like idle. I could have gotten more HP with a wilder cam but I really didn't want anything too lumpy.
Below is a link to a comparison dyno from both sets of mods.
http://www.comp-soln.com/Dyno3Run.jpg
These are videos of my car. The first was after the cam, and the second was after the heads:
http://www.comp-soln.com/Chips_C5-lowres.mov
http://www.comp-soln.com/AfterAFR205.mov
Hope that helps.
Chip
Old May 7, 2008 | 05:24 AM
jbusmc1986's Avatar
jbusmc1986
St. Jude Donor '06
I dunno what your budget is, but I am selling my brand new h/c setup for 1800 shipped.
Includes:
MS4 cam, PRC stage 1 ported ls6 heads, all gaskets, bolts, pushrods... etc
with this setup and a set of headers you would be in the high 400's to the wheels. There are 0 miles on this never installed setup. The reason for the sale is I am going supercharged instead. I am also selling a nx wet kit too.
Old May 7, 2008 | 07:12 AM
Corvette-Chris
St. Jude Donor '08
Includes:
Sounds` like a nice setup but I think those power goals are a little inflated
Old May 7, 2008 | 09:23 AM
jedblanks's Avatar
jedblanks
Originally Posted by ChipN
\My decision was to go with a cam, headers, and better air intake first. The results were very good. The next year I added heads (AFR 205) and a Fast 90 intake. \
Hope that helps.
Chip
I did cam only (228/232 +UD pulley +LS2 chain +hi flow oil pump +pushrods +PRC Dual gold springs +tune also), and it seemed to provide more bang for $2000 (someone else's labor)
Than for the $3300 on a budget I spent for 243 Heads and Dynatech Headers and LS6 intake I added a month later. (+ another tune + my labor)
If you do the cam yourself you can probably do it for $1200 with all the supporting goodies and a professional street tune.
Old May 7, 2008 | 09:48 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
that's Texas Speed/performance correct?
Hope that helps.
Chip
that's a nice smooth power curve. What are the specs of your "baby cam"?
Includes:
Why not do both? If you already have the parts a FI+H/C setup would be sick plus you pick up a crapload of bottom end. You might need to look at a different cam to match the blower but other than that what's your reason for selling?
Old May 7, 2008 | 02:06 PM
ChipN's Avatar
ChipN
It's a "secret" DTE grind. They told me when I purchased it but the only thing that stuck was the 115 LSA (I didn't know much about cam specs at the time). Haven't bothered asking since then.
At one point one of the guys on the forum (Vettenuts) posted a graph of various people with QTP headers. The cars were pretty comparable. My car outperformed the others and the only real difference was the cam, so I'm a believer.
There is torque everywhere - sometimes too much. I can be passing someone on the highway, accelerate without downshifting (A4), and have the tires break free if I give it a little too much gas (I'm running Z06 rims and F1 Supercar tires with 3.42 gears). It is kind of fun unless you are not expecting it. It makes me wonder what those guys with 450-500+ rwhp do...
Chip
To Heads before Cam?
