Fuel Filter 98 Vette
Old May 9, 2008 | 03:50 PM
etsfl's Avatar
etsfl
Default Fuel Filter 98 Vette
On the 98 Vette with automatic transmission access to change fuel filter is very limited. After removing the drivers side muffler,I still could not get both hands in squeeze the plastic tab with one hand and pull on the filter with other hand.
I finally was able to remove it with ease by attaching a small vise grip to the plastic tab and than with 1 hand pulled of the line from the inlet and pulled on the filter to remove it from the outlet line. Took all of 2 minutes to replace.
Attach the vise grip so it only squeezes down on the plastic tab enough to release the 2 locks.
Old May 9, 2008 | 04:05 PM
ALVETTE00's Avatar
ALVETTE00
Nice tip...mine was done during the exhaust removal!
Old May 9, 2008 | 04:37 PM
jrprich's Avatar
jrprich
Insane placement by GM
Old May 9, 2008 | 04:52 PM
fixvet's Avatar
fixvet
I've got a new filter for my '98 A4, but just haven't crawled under there yet to do the deed! Is removing the DR muffler actually necessary? I've never heard of that being done before.
Thanks,
Old May 9, 2008 | 05:39 PM
aquaholic's Avatar
aquaholic
i was trying to post a pic of the filter removal tool but couldn't get it from my hard drive to this post. anyone know ho to do this?
Old May 9, 2008 | 06:10 PM
fixvet's Avatar
fixvet
No pics, but I'm sure I got my set of about 8 diff. sizes at Kragens........for only about $8. There are some fancy billet alum. ones out there for alot more moolaa, but they don't do anything different than the plastic ones. I'd rather put my cash in my gas tank these days!
Old May 9, 2008 | 08:05 PM
Cadillac Tech's Avatar
Cadillac Tech
Thanks,
You can replace the filter without removing the muffler.
Bruce
Old May 10, 2008 | 12:48 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Related question. How much fuel rains down on you when replacing the filter? And do you need to depressurize the fuel system beforehand?
Old May 10, 2008 | 09:29 AM
etsfl's Avatar
etsfl
The reason I replaced fuel filter was it developed a leak at the outlet connection.When I looked at it right after turning ignition off there was a steady leak for a few minutes untill it depresurized.
When I removed the inlet line to filter,the fuel that remained in the top poured out. I than tipped the filter down and drained some fuel into a small can.
I would definetly recommend depresurizing the system before disconnecting a line
To Fuel Filter 98 Vette
