AC Doors Inoperable
The oil pressure gauge works again! (And the engine started with no problem).But the AC vent controls are now inoperable. The vents are stuck in a half foot, half dash mode. (Temperature control is normal).
The instructions I used warned about this potential, indicating that a small vacuum connection at the back of left side of the intake manifold needed to be reconnected because it powers the AC vents.
I checked - that hose is connected firmly - but still no vent control.
I also noticed a threaded cap near that connection on the same line. It was loose when I checked it. I tightened it by hand - still no vent control.
Questions:
1. Is there anything else I might have forgot to reconnect that is causing my vents to not be controllable?
2. Is there a simple way to test for vacuum at this connection?
3. Is there anything else I could do to diagnose or solve this problem?
http://forums.corvetteforum.com/show....php?t=1966898
http://vette.tnreeds.com/actuator/actuator.htm
No codes. AC doors still inoperable. Strong vacuum at the intake manifold and just prior to what looks like some sort of valve. None past the valve - whether I leave it plugged in or unplugged.
To check for a bad valve, I bypassed it with 1/4" tubing, connecting the nipple on the manifold to the metal pipe at the firewall. Strong vacuum all the way - still all doors inoperable.
I checked all fuses - all OK. The HVAC module appears to be working normally - i.e. all lights are on, everything cycles as normal on the screen.
The temperature control and fan speed adjustment work normally.
Everything worked normally before I replaced the oil sender.
Any help would be appreciated.
