Mod Woes... what to do?
Old May 11, 2008 | 03:30 PM
casslaw's Avatar
casslaw
Default Mod Woes... what to do?
I know there are a million answers to this question, and I have read every available thread, but I would like some help.
I just spoke to Jeremy Formato to tune my car (99 FRC 90k miles, K&N cai, Magnaflow x-pipe and cat back), and he suggested to install an LS6 intake and ported TB along with the tune. This got me to thinking....
I DO NOT want to put headers on the car, and with the mileage, I don't plan on doing a rebuild either, so I want to stay mild, but get the most out of what is available. I don't want to change the heads, so I was wondering if throwing a cam in there along with the intake and tune would be a good idea? The obvious answer is yes, and then it comes to picking a cam that would work the best with stock heads and bottom end? Also, I don't want to affect the driveability or gas mileage of the car (as much as possible). I haven't asked Jeremy for his opinion yet (he is out tuning for the next two weeks), so I am asking if you guys think the money for the cam/intake/tb/tune will give me a good return with power, or if I should just leave it alone until I do a rebuild with a heads/cam/intake package? I know there are a lot of questions here, but any help would be appreciated.
Old May 11, 2008 | 04:23 PM
zeevette's Avatar
zeevette
If you want, you can have the best of both worlds. Do the whole heads/cam/LS6 intake at one time, and increase your power significantly, while also increasing your fuel mileage. Get some aftermarket heads that'll increase your compression to about 11:1, and about a 224/228 @114+4 cam. This will not change your drivability much, with a Formato tune, and will change your car into a real beast. I don't understand your aversion to headers, as these are a great building block for the other mods, and there's really no downside.
Old May 11, 2008 | 04:30 PM
casslaw's Avatar
casslaw
Maybe I haven't done the research on the headers, but I want something that will bolt up to the stock pipes going to the cats. My aversion is simply my attempt to stop me from getting stupid and doing it ALL. I have a problem with temptation. I swore when I bought this car that the K&N and the Cat back was all I was going to do, but darnit, I want more.
Old May 11, 2008 | 04:32 PM
thetaxman's Avatar
thetaxman
I understand the header issue
short tubes are a waste and long tubes are not smog legal
Old May 11, 2008 | 04:44 PM
happa's Avatar
happa
I have Stock LS6 Heads, Stock LS6 Intake, G5X4, LG Pro's Lt's, and B&B Bullets. I made 431 rwhp and 415 ftlbs. and still get 29.7 mpg on the highway and 20 ish around town. You can do that set up or a smaller cam to get a better driving ability. Love mine got the a decent amount of power and still great on gas. just my .02, good luck!
Old May 11, 2008 | 05:06 PM
BitViper's Avatar
BitViper
Shorties aren a waste..just not cost effective
Old May 11, 2008 | 05:17 PM
casslaw's Avatar
casslaw
Those are great numbers, I am just looking for that "stock" look and I know if I get started, I can't stop, that's why I am trying to decide to stuff a cam in there along with the intake, or just do the intake and tune and wait for a rebuild. Thanks
Old May 12, 2008 | 11:57 AM
thetaxman's Avatar
thetaxman
since you don't get any performance advantage, they are a waste
Old May 12, 2008 | 12:07 PM
99C5JA1's Avatar
99C5JA1
A cam or heads without a good set of long tubes isn't going to do much. Your engine is an air pump how much it can expel limits what it can take in. So without addressing the exhaust properly, you'll simply choke any mods. Most good long tube setups will replace the exhaust all the way to the rear section.
And yes shorty headers are a waste.
Old May 12, 2008 | 12:20 PM
lucky131969's Avatar
lucky131969
I would not touch the car if you use gas mileage and performance in the same sentence. If gas mileage is your primary concern, leave the car alone.
Old May 12, 2008 | 12:46 PM
ROJO99's Avatar
ROJO99
If I could start from scratch I would go straight to FI. Thats the direction I am going now . Anyways A set of LT's and the proper cam can go a long way. Lt's and a CAI can do alot for these motors. On a side note, a Clutch will be needed once you up the C5's HP past 350RWHP, which is not hard. I toasted my factory unit with only Lt's, Ls6 intake, Vararam and DR's. But I did manage a low 12 second pass before the clutch went south. I guess I am saying add the clutch price into any HP adding mods...
To Mod Woes... what to do?
