Radiator Hose collapsing
Old May 11, 2008 | 06:29 PM
Masummerrain's Avatar
Masummerrain
Default Radiator Hose collapsing
Chg. my anti-freeze with new extended life Dex-cool followed the Service Manual for 2000 Vette / Engine Cooling page 6-345 did it three times and I also tooke the top radiator hose off and filled the top hose to the Eng. and still the top radiator hose keeps collapsing. When Eng. is up to 210 the top / bottom and heater hoses are hot. There not much pressure at all when I remove the surge cap. Never noticed this before as I clean under the hood all the time wiping down the hoses, etc.. Could this be a weak radiator hose. Drove car and does not over heat. I also left the surge cap off till it reached 210. No Luck . ANY IDEAS. THANKS
Old May 11, 2008 | 06:31 PM
ecoman's Avatar
ecoman
T-stat could be sticking might have a air pocket .
Old May 11, 2008 | 06:35 PM
Masummerrain
If T-stat is sticking Y would the water in surge tank , and hoses be hot if water is not circulating.
Old May 11, 2008 | 06:44 PM
hotwheels57's Avatar
hotwheels57
Hoses collapsing might be an indication of the pressure cap "surge cap"?? (on the reservoir) being defective and hoses being old. The radiator might also need inspection.
Old May 11, 2008 | 07:23 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
If the upper radiator hose is collapsed after the engine cools,the vaccum relief valve in the cap is defective.
Repacing the cap should fix it.
Old May 11, 2008 | 08:36 PM
Oldvetter's Avatar
Oldvetter
This problem and solution has appeared here before.
Old May 13, 2008 | 08:24 AM
Masummerrain
THANKS // THANKS // and THANKS Replaced the Surge Cap and everything is fine.
Old May 13, 2008 | 08:25 AM
Masummerrain
THANKS FOR YOUR INFO: Replaced the Surge Cap and no more problem with top Hose . Again Thanks for you support. Tony
Old May 13, 2008 | 08:28 AM
Masummerrain
Thanks for your help I replaced the Surge Cap and the Top Hose dose not collasp again THANKS FOR YOUR INFO: Tony
Old May 13, 2008 | 09:10 AM
DPG's Avatar
DPG
St. Jude Donor '06
thanks for posting that this fixed your problem
Old May 13, 2008 | 09:45 AM
Quicksilver Vert 01
Glad to help!
Old May 13, 2008 | 10:27 AM
87SAM's Avatar
87SAM
Normally we never hear the outcome
Old May 13, 2008 | 02:13 PM
hotwheels57
...normally, we seldom have a consensus of opinion, either...
Old May 13, 2008 | 03:33 PM
DPG's Avatar
DPG
St. Jude Donor '06
i don't care for your opinion j/k
To Radiator Hose collapsing
