C5 Rear rotor/caliper/bracket Q??
Bill
Bill
Anyhow, that's how I put it back together, I just slid the new brackets onto the pins w/o loosening or tightening anything. Put the pads back in, put them on, and then torqued the caliper bolts to 125. I drove it, not very far, everything seemed fine.
I think we need some definitions here -
The calipers bolt to the caliper brackets using the smaller bolts, and they only require 23 ftlbs of torque.
The caliper mounting brackets are mounted with two large bolts that require 160 ftlbs *(I think - working from memory on this one...)
So - you could have mounted the calipers and brackets as one unit - and then just tightened the caliper mounting bracket bolts down to spec and then hook up the hydraulics and be fine.
Check out this link for more pictures - because pictures > 1000 words.....
http://www.iammoon.com/c5tech/caliper_painting.htm
best regards -
mqqn
I am talking about the caliper mounting bolts. Do the caliper brackets just "float" on the pins that are on there? I slid the old brackets off the pins, and slid the new Z51 brackets onto the pins, installed the pads, put everything back together.
I guess my question really is, how do I torque the caliper mounting bolts to 23lbs, when I do not even do anything to the caliper mounting bolt other than remove the old brackets and put the new brackets on???
Here is a picture:
Where number 1 is the bolt, number 2 is the caliper, number 3 is the caliper bracket, number 4 is the boot, and number 5 is the pin. There are two flat spots on the pin (usually hidden just inside the boot) that allow a 17 mm open end wrench to be fitted to the pin so you can tighten the bolt.
If you got these two bolts and the two bolts that fasten the whole assembly to the knuckle tightened properly then you should be OK.
Bill
I am so confused b/c, I did not loosen anything to pull the caliper bracket off, they just slid off the pin, I took the boot off the original bracket, put it on the new bracket, and slid the new bracket back on the guide pins.
I never loosened the guide pin bolts that attach the guide pin to the caliper.
I suspect this is what you did ......
1) You received from someone/somewhere a C6 caliper already installed onto the caliper bracket.
2) You undid the 125 ft/lb bracket bolts (The one's in mqqn's picture that says "these stay in place") and the brake line and removved the C5 caliper and bracket in their entirety.
3) You put the C6 caliper and bracket assembly on with the bracket bolts tightened correctly to 125 lb/ft
4) You replaced brake line ... you're done
That should in fact work.
Is that what happened ??????
No...I bought new c6 z51 rotors and brackets
-I removed my calipers, but did not unhook the lines
-removed the rotors (I recieved the brackets after the rotors)
-Once the brackets came in, I removed the original caliper brackets by sliding them off the mounting pins, the caliper mounting pin bolts were not removed.
-I slid the new brackets on the mounting pins just opposite of the way I slid the factory caliper brackets off.
-I installed the brake pads
-I reinstalled the calipers on the rotors w/the new c6 z51 brackets and torqued the bolts to the knuckle to 125lbs
-I spun the rotors on each side to make sure they turned ok, they did, no rubbing
-I put the wheels back on and drove it down the road about a mile then back...no problems!!
I guess I am just second guessing the procedure after reading about having to torque the caliper mounting pin bolts to 23 lbs??? How can I retorque them if they were never untorqued? Unless, I did the install wrong?!?!
Again its your terminology .... in your first step you removed the caliper AND bracket (as I guessed) by undoing the caliper bracket bolts (The one's in mqqn's picture that says "these stay in place")
Normally the bracket is not removed, so to replace the brake pads you will need to undo at least one caliper guide pin bolt to swing the caliper away from the pads.
Have fun with it .....
