Installing Power Steering Pulley
Old May 13, 2008 | 11:20 PM
jon c's Avatar
jon c
Default Installing Power Steering Pulley
will it be OK to wrap up the pulley good and clamp it in a vice to hold it while I crank on the install tool, having a hard time holding the pulley and turning the install toll to put the pulley back on.....
Old May 14, 2008 | 12:31 AM
94legaleagle's Avatar
94legaleagle
Good luck - I had to use an impact wrench to get my pulley on
Old May 14, 2008 | 12:34 AM
jon c's Avatar
jon c
Thanks I thought about that but the install tool I have wont let me do that the nut on top is too close to the same size as the nut that pushes the pulley on I would be turning both nuts
Old May 14, 2008 | 12:43 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Well, I wouldn't put it in a vise since the pulley is plastic. It's pretty brittle. I use a Mac tools install tool and it works great. If you rented it, try another auto parts store for a different brand. If you didn't, still try the auto parts store and rent one.
Old May 14, 2008 | 03:54 PM
jon c's Avatar
jon c
Thanks for all the help guys, I finally got it done I guess I was being a little impatient with it....
Old May 14, 2008 | 04:00 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
Closed per OP.
To Installing Power Steering Pulley
