% of power loss through drive train?
Old May 14, 2008 | 04:01 PM
Lakesvette's Avatar
Lakesvette
Default % of power loss through drive train?
If I get 400 rwhp through 373 gears what should it be at the crank?
Old May 14, 2008 | 04:02 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Auto 15-17% or stick 10-15%
Old May 14, 2008 | 06:00 PM
motogib1's Avatar
motogib1
Drivetrain loss will be a bit more for the 3.73 gears than through the stock gears.
Old May 14, 2008 | 10:23 PM
99mallett's Avatar
99mallett
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
According to Mallett Cars, which did my conversion, they figure driveline loss at 17% for manual and 22% for auto. My car hits about 388 rwhp on the dyno, and is rated at about 500ghp @ crank. That's 388/.78 = 497.44, so that's pretty close. Numbers listed above are too conservative.
So, 400rwhp should be about 512hp for auto and 481 for manual.
Old May 15, 2008 | 12:32 AM
nuck's Avatar
nuck
For a 6 speed about 450 based on a C5 Z but that would adjust slightly up if you are running a heavy wheel/tire comb.
It isn't a fixed percentage. Most of the loss is due to the weight of the reciprocating mass you are spinning which doesn't increase as the engine output increases. Only frictional losses change.
Old May 15, 2008 | 02:14 AM
Corvette Don's Avatar
Corvette Don
Thats a LOT of loss
Old May 15, 2008 | 07:43 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Years ago we did a drivetrain loss test on a dyno. If I remember correctly after a dyno run I had to let the car wind down on its own and not hit the brake for the dyno. When this was taking place the dyno had the software to read such a thing.
On my 6 speed with 3.73 gears it was only 8.5% drive train loss. If this is true, Chevrolet did wonders for allowing us to put more HP to the ground.
Old May 15, 2008 | 12:34 PM
screw991le's Avatar
screw991le
22% is way to high. That would translate into a 2000 coupe putting 273 RWHP to the ground. That means my 2000, which puts 302 RWHP (stock) to the ground would make my engine close to 390 crank HP. Ahh no.
Old May 15, 2008 | 12:39 PM
edcmat-l1's Avatar
edcmat-l1
The chassis dynos the have at the Bosch shops in Germany had that capability. And thats exactly how they performed that test.
Old May 15, 2008 | 12:43 PM
edcmat-l1's Avatar
edcmat-l1
A C6 Z06 makes 505 at the FW, and about 443 at the wheels on my DJ. That comes out to 12/12.5% using your math above. Right about what I believe to be so.
Also, if you run these autos with the converter locked, the auto trans equation goes out the window. You can then assume a loss very similar to a manual.
Old May 15, 2008 | 04:00 PM
zeevette's Avatar
zeevette
And you're believing them because you spent alot of money, right?
Stock C5Zs, rated @ 405HP typically run about 350 RWHP, so can't we assume a 55hp drivetrain loss? And why would this loss increase as power is raised via modding? I think percentages are just a VERY rough guide to use, and even dyno readings have huge variances.
To % of power loss through drive train?
