Brass PS401 Oil Pressure Sensor
Old May 15, 2008 | 10:44 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Default Brass PS401 Oil Pressure Sensor
Can anyone say if the Standard PS401 Pontiac/Buick sensor has the same output calibration as the OEM Corvette sensor?
I'm not looking for a lab comparison test of the two sensors. Just actual oil pressure readings from the same engine,before and after replacing the stock sensor,with a PS401 sensor.
Old May 15, 2008 | 10:55 AM
c5streak's Avatar
c5streak
Yes, if you read through the oil sender relocate sticky at the top, "426hemi" used the PS401 sender and his pressure was spot on what the stock C5 unit was.
Old May 15, 2008 | 11:11 AM
Quicksilver Vert 01
Thanks,I did read the entire sticky. I must have missed that important point!
To Brass PS401 Oil Pressure Sensor
