Differences in C5 OEM exhausts
Old May 16, 2008 | 03:31 PM
Casem1's Avatar
Casem1
Default Differences in C5 OEM exhausts
Guys, after spinning out at my last HPDE, I dragged my H-pipe across the corner's rumble strip. Although it didn't puncture, it is 'altered' quite a bit.
Anyway, I will eventually replace it but was wondering if I could go with a newer pipe (car is a 99 with 30k miles, would like to have another with comparable or fewer miles on the cats, I'm **** sometimes). While thinking about this I recall reading about the Z06 exhaust manifolds being lighter. Is this true? I doubt there would be any change in flow, but if I swapped an 01-04 exhaust (already have the Tis) would I gain any weight savings? My 99 manifolds are flat out heavy, and I already sold my headers and choose to not go back. I understand that I would need a new AIR pipe, did that with my headers already in the past.
P.S. - I have no desire to use pup-cats, am I correct when I say on the 2000-2001 had pup cats???
Old May 16, 2008 | 10:00 PM
Casem1's Avatar
Casem1
I didn't stump you guys, did I
I spent a while searching and all I found was some posts about 97-99 being double walled and 01-04 are not. But they may be diff material? Search really wasn't my friend.
Anyway, when did people start charging big $$$ for H-pipes? I remember a few years ago people struggled to give away stock H-pipes... My tuner has a stack in his dumpster!
Old May 16, 2008 | 10:32 PM
kerryt1's Avatar
kerryt1
You could probably get a complete Z06 exhaust (front to back) for $6-700 or so, maybe less. It would be an improvement, and it seems like I saw something saying the LS6 manifolds were redesigned from the LS1. Not sure, though. 2001 does have pup cats.
All that said, why not upgrade to some longtube headers?
Old May 16, 2008 | 10:34 PM
nextime's Avatar
nextime
Are pup cats bad? I have a 2001.
Old May 16, 2008 | 10:42 PM
kerryt1's Avatar
kerryt1
No, it's just probably a little more restrictive. 2001 still has 350 HP instead of 345, right? Everyone needs headers anyway...
Old May 17, 2008 | 01:21 AM
4DRUSH's Avatar
4DRUSH
We're just in shock. NO HEADERS
Old May 17, 2008 | 10:27 AM
Casem1's Avatar
Casem1
I already had longtubes and I did not like them... Numbers were good but I care about more than numbers. I used LG's for a year.
Anyway, the exhaust on the Z06 is the same as the later C5's, same part numbers. If that would cost me $6-700 I won't even bother. I will try to find an h-pipe that hasn't been dragged across the corner strips at a track eventually that isn't $300...
Old May 17, 2008 | 12:39 PM
fdxpilot's Avatar
fdxpilot
Call LG. They usually have a pile of them. They did when they added mine to the pile.
Old May 17, 2008 | 02:17 PM
Bill Dearborn's Avatar
Bill Dearborn
I believe GM changed the exhaust manifolds in 2001 from stainless steel to cast iron. 97-00 had the double wall stainless ones. Supposedly the newer manifolds provided better exhaust flow and were lighter?? That was part of the 5 HP increase on the LS1 engine.
Bill
Old May 17, 2008 | 10:00 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Casem1 -
I was going to suggest the same thing that fdxpilot did - you can get a nice take-off system from LG - when I was there they told me they let them pile up and then someone comes and takes the pile away.
best regards -
mqqn
To Differences in C5 OEM exhausts
