High Voltage Issue
Old May 18, 2008 | 11:05 AM
bbentley40's Avatar
bbentley40
Default High Voltage Issue
I have been having a high voltage issue on my car for a few weeks now. I have tried all the normal stuff.. checking grounds, battery terminals, charging battery, even used Bill C's post and took out the ign switch and cleaned it up (had a couple burned spots on it). But none of that has fixed my high voltage issue.
Basically, when I put the key in and turn it to the On position my car is already reading close to 15v. I have verifyed that the battery is not reading that. When I start the car it creeps up to above 18v and the IPC just shuts down. I am thinking my problem is in the IPC. I have searched the forums and found a couple people that had this problem and they have said they had to replace the IPC.
Now my questions. Do I have to replace the entire IPC or can I just replace the bread board in/behind the guages? My car has a HUD so I am assuming I have to have a HUD IPC, but if I can just replace the board will it matter if its a HUD IPC or not? Also, if I have to replace the entire IPC, can anyone suggest a good company to send the new IPC off to so I can get the milage corrected to my current milage?
Thanks all!
Old May 18, 2008 | 05:22 PM
aquaholic's Avatar
aquaholic
sounds to me like you need to replace the alternator. i'de start by removing it from the car and having it tested before i started replacing expensive circuit boards. any local automotive electrical shop should be able to test and/or rebuild it for you if that is the problem.
Old May 18, 2008 | 09:51 PM
bbentley40's Avatar
bbentley40
I have tested the alt to verify that it is putting out approx 14 volts. That was one of my first things I tested.
Old May 18, 2008 | 10:23 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
So you're saying that the IPC isn't reading the correct voltage and that it doesn't agree with the actual voltage. Right?
Old May 18, 2008 | 10:43 PM
bbentley40's Avatar
bbentley40
Yep, thats it. The IPC reads approx 4 volts to high. It does not do it 100% of the time, but it does it about 80% now. I have checked the battery and the alt.. both are putting out the right voltages.
Old May 19, 2008 | 05:19 PM
bbentley40's Avatar
bbentley40
Any input??
Old May 19, 2008 | 05:21 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Send a PM to Bill Curlee. He's the electrical expert here.
To High Voltage Issue
