Difference between MAS ends and GMS Mas?
Old Dec 18, 2001 | 01:38 PM
Phil97SVT's Avatar
Phil97SVT
Default Difference between MAS ends and GMS Mas?
Whats the long term performance difference between adding new larger MAS ends vs going with new MAS?
Phillip
Old Dec 18, 2001 | 01:49 PM
Chris@SD's Avatar
Chris@SD
Default Re: Difference between MAS ends and GMS Mas? (Phil97SVT)
Neither one will get you anything except maybe manipulating the AFR ratio, but there are better ways of doing that! The MAF is not a bottle neck in the stock intake tract.
Good Luck,
Old Dec 18, 2001 | 01:52 PM
C5Cemo's Avatar
C5Cemo
Ditto to what Chris said...and I'll add:
GMS reprograms the electronics as well as putting on larger ends. Their programming has been proven to be very inconsistent, you could get a good one or a bad one. Also, their MAS is considered a way to fix a lean condition but you'd be better off with a MAFT and Autotap for that. You'll be able to dial it in exactly where you want it with that combo instead of dealing with a fixed setting with the GMS.
Old Dec 18, 2001 | 01:56 PM
Chris@SD's Avatar
Chris@SD
Default Re: Difference between MAS ends and GMS Mas? (C5Cemo)
Well said Cemo!
So when are we going to get together for a little 1320' sprint!!! :) If you beat me, I will buy you a beer!!! :cheers:
Old Dec 18, 2001 | 01:59 PM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
Default Re: Difference between MAS ends and GMS Mas? (Chris@SpeedDemon)
Let me know when and where. I wanna watch, provided I can keep up with you guys. :D
-Tuan
Old Dec 18, 2001 | 02:01 PM
C5Cemo's Avatar
C5Cemo
I should have her back on the road today or tomorrow :smash: :smash:
I'll be willing to give it a go real soon :cheers:
Looking forward to it...thanks
Old Dec 18, 2001 | 02:13 PM
Chris@SD's Avatar
Chris@SD
Default Re: Difference between MAS ends and GMS Mas? (leanhtuan)
Tuan,
Check my special on TNT Nitrous kits below! Sure would help you keep up!!! ;)
Old Dec 18, 2001 | 07:55 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Phil I recommend reading my article on modding and its effects:
http://www.vetteguru.com/mods/howto
By the way here is an excerpt from Chief GM Powertrain Engineer, John Juriga regarding the 385 HP LS6 in an interview with Hib Halverson.
""The other changes for the LS6 are the higher-capacity mass air flow (MAF) sensor from the 6.0-liter, Gen III truck engine. It’s worth 2-3hp and its integral intake air temperature (IAT) sensor simplifies the engine controls and reduces cost."
To Difference between MAS ends and GMS Mas?
