Yes, the car will be harder to get on a lift, jack or a rollback.
Yes, the car will be easier to bottom out.
No, the lowering will not screw up the tires, wheel wells or computer. Fairly big tires will still fit. I'm running 275/30/19 and 305/30/19 on my lowered car just fine.
As others have posted, turn the bolts and drop it. The 1" or so you'll get won't hurt anything.
I just ordered a set of front & rear lowering bolts from West Coast Corvettes. Althought there are considerations that you need to take into account if you're going to lower your car such as making sure you get a proper 4 wheel alignment to set the camber & toe back to where it should be so you don't wear out those expensive rubbers, the one thing I haven't seen discussed that is more of a concern to me is the reduction of shock travel available when the car gets lowered. It seems to me that in order to really make this all work you need to get a set of shorter shocks that are a bit stiffer to make sure you don't bottom out on the rebound bumpers every time you hit a bump. I don't know how much travel the stock shocks have but if you lower the car you compress the shock and reduce the amount of travel available. I'd really like to see someone chime in that's addressed the lowering process correctly. The only other way to do this right is to go with a set of coilovers$$$$$$.
who dude, you do know that lowering on the stock bolts lowers it less than 3/4 in, right? absolutely no problems with shocks will result
That number seems to be all over the place based on what I've seen posted. Seems to make a difference depending on what suspension package you have. Think I'll lower using the stock bolts and see what I get. If I need to go more then I'll use the kit I bought and depending on how much lower I go I'll get shorter shocks. I've seen ones from Pfadt that are made to work with the car when you lower it. Not sure if anyone else makes them that way. A lot less expensive than coilovers.
