clean trans and diff
Old May 19, 2008 | 02:01 PM
95formula's Avatar
95formula
Default clean trans and diff
Just pulled the trans and diff to replace clutch. What is the best way to clean the trans and diff? Will be changing both axle seals.
Old May 19, 2008 | 02:28 PM
MikeV's Avatar
MikeV
Simple green and the hose unless you need more. Than walmart carb cleaner in a can. By the way this is a good time to put in a hardened shaft on the long side of the differential.
Mike V
