Cv Joints On A C5??
Old May 20, 2008 | 11:30 AM
UWEBABY's Avatar
UWEBABY
St. Jude Donor '06-'07-'08-'09
Default Cv Joints On A C5??
I Need A Quick Answer On This If I Can Get One.
I Dropped My 04 Off At My Dealer For Service. Writer Called Me To Say That During The Service They Noted That The Cv Boot Had Been Cut Open And Was Throwing Grease.
I Didnt Know That The Corvettes Used Cv Joints. My C4 Had U Joints On The Inside And Outside Of The Impeller Shafts.
Do C5's Have Cv Boots??
Old May 20, 2008 | 11:34 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Yep. CV joints in the rear.
Old May 20, 2008 | 02:21 PM
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
A pair of CV's on each of the left and right half-shafts from the diff to the wheels.
Old May 20, 2008 | 02:23 PM
MattB's Avatar
MattB
Yep, actually a inner and an outer CV joint. You can find whole remanufactured axel half shafts for less than rebuilding, like $70 from rockauto.com.
Its a big job replacing anything on the CV joint. A bit of the rear suspension on that side needs to be removed to get to it. Labor will be the biggest part of the bill.
Old May 20, 2008 | 04:20 PM
Corvette Don's Avatar
Corvette Don
Its not that big of a job, if you have a few hours and like to work on your car it can be done pretty eaisly (changing the boot), I did mine for $15. I am too the point to where I can remove a CV axle in 30 mins w/ air tools
Old May 21, 2008 | 07:50 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
You have to do the same amount of work to remove and install the axle that you would have to do to remove the axle, replace the CV joint and reinstall the axle.
Old May 21, 2008 | 09:26 AM
UWEBABY's Avatar
UWEBABY
Thanks To All For The Information. I Went Down To Look At The Car On The Rack. There Was A Small Tear In The Outer Boot On The Pass Side. Grease Was Thrown Into The Wheel Well. Cost 250 To Replace.
Again, Thanks For The Tutorial.
To Cv Joints On A C5??
