Climate Control Gremlin?
Old Dec 18, 2001 | 10:27 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Climate Control Gremlin?
The automatic climate control on my '01 has recently developed a problem: with the passenger temp set in the normal midway position, I must set the driver's temp to a very cool setting (maybe 65') if I want to cool the car to about 72' actual on a warm day, and I must set the driver's temp to a very warm setting (maybe 80') if I want to heat the interior to about 72' actual on a cold day. The situation does not change when the interior reaches the desired temp, I have to keep it set about 80' all day long to stay warm on a chilly day. Can anyone suggest what is causing this problem?
[Modified by Gearhead Jim, 8:30 PM 12/18/2001]
Old Dec 18, 2001 | 10:41 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Climate Control Gremlin? (Gearhead Jim)
A bad temperature sensor on the driver side?
Old Dec 19, 2001 | 12:59 AM
NJVetteGuy's Avatar
NJVetteGuy
My climate control had trouble with not giving me heat. Dealer replaced the HVAC controller under warranty and that fixed the problem. I don't know if a bad temp sensor input was to blame, or even a poor connection given the history of poor quality with my car (8 visits in the past 6 months, 2 of which were over a week each). I had no codes with the heat problem...did you check for DTCs?
Old Dec 19, 2001 | 12:55 PM
kenrobb's Avatar
kenrobb
My problem was the right side door postioner was bad. Door would not move. that was replaced and works fine now. It had a code saying it was bad. Have you checked the codes?
Old Dec 19, 2001 | 01:03 PM
Gearhead Jim
St. Jude Donor '13
Default Re: Climate Control Gremlin? (kenrobb)
I was hoping that there was some easy fix I could perform by myself, but it's beginning to sound like a warranty appointment is in my future. Thanks for the comments.
To Climate Control Gremlin?
