Hi, If you have verified that the refridgerant level is proper, try a recalibration. SEE BELOW LINK
You may want to try the recal first since it is easier.
Good Luck http://forums.corvetteforum.com/show....php?t=2030291
i also noticed the air is not controlled like it should,if you switch the mode ,like to under dash and out front or defrost,it all seems the same,like the air flow never changes direction,,
Exactly the same out of mine, it all blows cold but doesnt blow hard at all and it doesnt matter what setting its on the air always distributes how it wants. Also i have a leak under the dash. Any advice guys?
That sounds like a vacuum issue. You need to check all vacuum lines for breaks or leaks. Start with the manifold line back of the engine and follow it to the vacuum tank,(right side wheel well area), and to the vacuum control assembly under right side of dash. Take a look under the battery tray for battery acid damage and broken lines.
Good Luck
================================= Mode Valve
The mode valve in the at-rest (no vacuum) position, allows a blend of air to the instrument panel and the floor outlets; as in BI-LEVEL mode. The mode valve can be opened (full-down) or closed (full-up) by applying vacuum to one side or the other of the three-position mode valve vacuum actuator. When opened (full-down) by applying vacuum to the lower side of the vacuum actuator, air will exit the instrument panel outlets (air is blocked off from entering the floor outlets); as in UPPER mode. When closed (full-up) by applying vacuum to the upper side of the vacuum actuator, the instrument panel outlets will be closed off and air will be delivered to the floor outlets depending on the corresponding position of the heater valve; as in LOWER or DEFOG modes.
Edit-To solow1k water on floor sounds like your condensate drains are clogged up. Should be a Evaporator module drain tube running along the cowl in the vicinity of the ac/heater module. If you can find it snake it out carefully.
