How do I Disable Tire Sensors Without Error Codes?
Old Dec 19, 2001 | 01:55 AM
CABNETMAN's Avatar
CABNETMAN
Default How do I Disable Tire Sensors Without Error Codes?
Per Topic,,,Thanks,,,Tom
Old Dec 19, 2001 | 02:29 AM
Austrian Vette's Avatar
Austrian Vette
Default Re: How do I Disable Tire Sensors Without Error Codes? (CABNETMAN)
Would like to know also!!
Michael
Old Dec 19, 2001 | 02:59 AM
C5 Frederik's Avatar
C5 Frederik
Default Re: How do I Disable Tire Sensors Without Error Codes? (Austrian Vette)
Same for me. Can dealer do it?
Frederik
Old Dec 20, 2001 | 01:42 PM
CABNETMAN's Avatar
CABNETMAN
Does anyone know?
Old Dec 20, 2001 | 03:02 PM
lotzahp's Avatar
lotzahp
I believe it is progammable in the BCM, via a Tech2 scan tool.
Old Dec 20, 2001 | 07:45 PM
99 The Hard Way's Avatar
99 The Hard Way
I am running Z06 wheels/tires on my 98 coupe. We could not get the sensors to work on the Z06 rims. I have been told i need new O-rings to solve the problems. For the mean time, my local vette mechanic programmed my car using another C5 to program my computer. I just put my sensors in a zip lock back & put them in a rear compartment. I only had to reprogram 1 time in the 6 months they have been on the car. I'm not sure exactly how it was done, but it was not that hard. Hope this helps someone- SCOTT
Old Dec 21, 2001 | 12:36 AM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
Default Re: How do I Disable Tire Sensors Without Error Codes? (maroon94)
IF you have your sensors in a zip lock bag. How do you keep pressure in/on them?? Don't they report that you have low tire pressure?
thanks
Old Dec 21, 2001 | 04:10 AM
C5 Frederik
Maybe it works like this: as the tire sensors are not turning in the bag (what they do when on the wheel), they do not send an information concerning pressure. But the car will recognize, that they are there. Same thing happens, when you are in your garage and let the engine run. In this case there will be no "Check tire system" on the DIC. So what maroon94 says seems OK. I´m also running Z06 wheels on a ´98 and I will take out the sensors out of my MAGS to try it. Thanx
Frederik
Old Dec 21, 2001 | 04:17 AM
robiferretti's Avatar
robiferretti
Default Re: How do I Disable Tire Sensors Without Error Codes? (C5 Frederik)
i'm also interested in the results :yesnod:
To How do I Disable Tire Sensors Without Error Codes?
