Bought HP tuners, having a problem
Old May 24, 2008 | 12:54 PM
Gicantor's Avatar
Gicantor
Default Bought HP tuners, having a problem
I recently puchased Hp tuners in hopes of disabling my column lock for good but I'm having a problem.
My OBD port is not working. If I plug the interface into the port it doesn't show power at the connector.
Now I am positive the problem is my car and not the cables,interface or software because I tested it on my friends Silverado and it works just fine.
I guess I'll start checking the simple stuff like fuses and grounds. Any other ideas feel free to chime in.
Old May 24, 2008 | 01:03 PM
marky_24's Avatar
marky_24
its shares the same fuse as the 12v outlet by the ac controls. its in the pass side foot well if i remember.
Old May 24, 2008 | 03:01 PM
Gicantor's Avatar
Gicantor
The 12V source near the AC controls has power so it can't be a fuse then.
Old May 24, 2008 | 04:55 PM
FRCTony's Avatar
FRCTony
I think it's the same as the cigarette lighter fuse. Check them all in the footwell, one of them is blown for certain.
Old May 24, 2008 | 06:41 PM
Gicantor's Avatar
Gicantor
It was fuse #29 that was blown. I replaced it and everything is all good! I reprogrammed the fuel cut off with Hp tuners and installed my CLB. Goodbye column lock problem!
Old May 24, 2008 | 07:16 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Where did you buy it! ! and how much! ! !
Old May 24, 2008 | 09:20 PM
Gicantor's Avatar
Gicantor
http://www.hptuners.com/
To Bought HP tuners, having a problem
