help with parking brake
Old May 25, 2008 | 06:29 AM
ronald49's Avatar
ronald49
Cruising
Default help with parking brake
hi guys i went to inspection i own 1998 silver coupe well it failed for parking brake wont hold it has new pads on front and back i put new ones on still brake dont hold car when running why this parking brake gets nice and tight when car is off but when you have car running and pull back parking brake its very easy help ok happy hoilidays all
Old May 25, 2008 | 06:43 AM
BlackZ06's Avatar
BlackZ06
The parking brake is a mechanical drum braake inside the rear rotors. It has nothing to do with your front and rear hydraulic disc brakes.
Makes no sesnse why it would work differently with the engine on or off.
Old May 25, 2008 | 06:49 AM
ronald49's Avatar
ronald49
Cruising
Default parking brake
well tell me then why is it parking brake is hard to pull up with car off then when its running and why wont it hold car thats why i failed inspection
Old May 25, 2008 | 07:12 AM
BlackZ06's Avatar
BlackZ06
The parking brake won't hold the car because either the brake shoes are worn out (not the disc brake pads ... the parking brake shoes) or the brake shoes are not adjusted correctly.
I cannot tell you why it feels different with the engine on or off (if that is what you are asking) ... from the handle inside the car it is a cable to the rear brake shoes ..... the engine has nothing to do with it.
Old May 25, 2008 | 07:18 AM
ronald49's Avatar
ronald49
Cruising
i just put new pads on back how do you adjust them
Old May 25, 2008 | 07:19 AM
ronald49's Avatar
ronald49
Cruising
i got disk brakes all around
Old May 25, 2008 | 07:22 AM
ronald49's Avatar
ronald49
Cruising
why is service abs keep coming on i noticed when i start my car if i left the heat on blower motor wont go on till i reset button why do they have same maxi fuse for abs and blower motor
Old May 25, 2008 | 07:42 AM
BlackZ06's Avatar
BlackZ06
OK .... READ THIS CAREFULLY ....
Your rear brakes have TWO .... yes TWO brakes in/on each rotor.
Each rotor has an hydraulic DISC brake .... INSIDE the rear rotor is a DRUM BRAKE.
The drum brake is actuated by a cable attached to the brake handle inside the car.
The disc brake is actuated by you putting your foot on the brake pedal which causes the master cylinder to pressurize the brake fluid to the brake calipers.
You need to remove the rear rotors to see the drum brake.
Old May 25, 2008 | 07:46 AM
BlackZ06's Avatar
BlackZ06
You don't adjust the pads ... the pads are for the DISC brake
INSIDE the rotor is a DRUM brake .... the brake SHOES can be adjusted .... look at the backing plate on the inside of the rear hub/brake assembly. There is a rubber plug on the lower part of the backing plate ... pull the plug.
Using a screw driver you adjust the brake shoes using the star wheel inside the rotor. If you can't adjust them ... you will need to remove the calipers and rotors to access and replace the drum brake shoes.
Old May 25, 2008 | 07:50 AM
BlackZ06's Avatar
BlackZ06
I have no idea what you are asking .... try asking again in English ... please.
Old May 25, 2008 | 07:55 AM
ronald49's Avatar
ronald49
Cruising
ok im going to try what you said ok ill take back wheels off again and look for plug ok thanx this is going to tighten parking brake
Old May 25, 2008 | 08:05 AM
rws.1's Avatar
rws.1
here...
check out this forum members web site...
Two fixes....
3. for adjusting the pads
4. for servicing the handle
http://www.ronjpics.com/Corvettestuff.htm
Old May 25, 2008 | 12:09 PM
ronald49's Avatar
ronald49
Cruising
Default help i need info please
ok i went outside i started my car parking break works in reverse good when i go foward it dont work i put new pads on back do think if i put new pads on front it will solve my problem pads in front dont look bad ok thanx
Old May 25, 2008 | 12:23 PM
BlackZ06's Avatar
BlackZ06
Last time I'm polite in this thread .......
YOUR DISC PADS HAVE NOTHING TO DO WITH THE PARKING BRAKE
The front DISC brakes have NOTHING to do with your parking brake .....
The rear DISC brakes have NOTHING to do with your parking brake ......
Look at the pictures in the post that rws.1 kindly gave you ......
THE PARKING BRAKE IS A TOTALLY SEPERATE SYSTEM FROM YOUR DISC BRAKES
If you don't get it after this post .... I don't know how to explain it more clearly to you .......
Old May 25, 2008 | 12:28 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
You got all your answers above to fix it, I think you need to take it to a Corvette shop and have them do it, As said before, IT ISN"T the pads....
Fill out your profile.....
Old May 25, 2008 | 01:31 PM
ronald49's Avatar
ronald49
Cruising
ok then why does parking brake work in reverse not forward ok calm down just trying to figure it out so i dont have to take it to stealership
Old May 25, 2008 | 01:33 PM
Mr.Bill's Avatar
Mr.Bill
When you apply the e brake how far does the handle come up?
Mine works great and I think it only comes up about 3 clicks or so.
To help with parking brake
Old May 25, 2008 | 01:50 PM
ronald49's Avatar
ronald49
Cruising
about halfway but its crazy it works going backwards not forward why
Old May 25, 2008 | 01:55 PM
Mr.Bill's Avatar
Mr.Bill
Take it to a Corvette mechanic. Try pulling the handle a bit harder and see what happens, I have to give mine a good tug for it to work right.
I have seen a lot of E-brakes that work different in forward than reverse if not pulled enough.
Old May 25, 2008 | 02:08 PM
ronald49's Avatar
ronald49
Cruising
ok thanks for everything guys
