Help with codes / ABS / Traction Cntrl
Old May 25, 2008 | 06:17 PM
leopoldml's Avatar
leopoldml
Cruising
Default Help with codes / ABS / Traction Cntrl
98 C5 - Stock
Lights on: Check Engine, Stability/Traction Control / ABS
Going thu diagnostics, have the following:
PCM: 0141 H C
0161 H C
1571 H C
1644 H C
TCS: No Comm.
BCM: 0432 H C
HVAC: No Comm.
Air Conditioner control went off as soon as the TC / ABS lights started to come on - so I am thinking its related. Help on where to start on this appreciated.... mikel
Old May 25, 2008 | 10:59 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I don't have a service manual to see if they're on the same electrical circuit, but I would recommend you check the fused in the passenger floorboard and under the hood next to the battery. Use a test light when checking them to make sure there is voltage on both sides and do it with the key in the full forward/run position so that the circuits will be energized.
Old May 26, 2008 | 12:17 AM
SinghZvette's Avatar
SinghZvette
Mine is a 98 coupe .. EXACT same problem .. was intermittent till it got permanent. I will bet it's your ignition switch. Here's the post on fixing it.
http://forums.corvetteforum.com/show...02&postcount=1
You can PM me with questions if you have any since I've been through living with the problem and then the satisfaction of fixing it myself. It's real easy and costs nothing.
To Help with codes / ABS / Traction Cntrl
