Glove box latch
Old May 25, 2008 | 07:12 PM
Terry13's Avatar
Terry13
Cruising
Default Glove box latch
Hi.
I have a 1998 Corvette and the latch on my glove box wont latch.Anyone know how to fix this.I am afraid to force the latch because its in the down postion and i dont want to damage it.I am afraid the light will run my battery down.And i cant find the fuse because it doesnt seem to be listed in the book.Any help would be appreciated.
Thanks,
Terry
Old May 25, 2008 | 09:35 PM
jornahow's Avatar
jornahow
Soon after I bought my 02 I shut the glove box, the latch tripped to the shut position before it was closed. I found that if I pulled the latch handle to the open position it re-set and then it would close on the next try.
Old May 26, 2008 | 08:19 AM
silversport's Avatar
silversport
my '01 does this too...that is exactly my fix as well...
Bill
Old May 26, 2008 | 03:24 PM
RPHCRMZ51's Avatar
RPHCRMZ51
my '01 as well.
Old May 26, 2008 | 11:31 PM
bestvettever's Avatar
bestvettever
Default Wd 40
Originally Posted by Terry13
Hi.
Thanks,
Terry
Hi, had the same problem, used wd40 on it and worked it in a bit. No problem since.
Good Luck
Old May 27, 2008 | 10:19 AM
jovette's Avatar
jovette
Yep, the latch on my '00 will do the same thing now and then..........just pull the handle, and flick the lever to the open position, and it then will close just fine.
Old May 28, 2008 | 07:59 AM
silversport
Good Luck
Hey, thanks...I'll give that a try...mine has done this since it was new...
Bill
Old May 28, 2008 | 04:07 PM
Terry13's Avatar
Terry13
Cruising
hey thanks to all who responded.I feel kinda stupid ,but live and learn. problem solved.thanks again.
Terry
To Glove box latch
