6 speed to automatic
Are there any threads on how to take out the 6speed and put in an automatic? It would be nice not to have to worry about a missed gear or the flywheel coming up through the floor . I just don't think the tremec 6speeds can handle a 500rwhp vette for even 1 day at the track,nevertheless an entire season. Any comments would be appreciated. thanks! Greg O.
Are there any threads on how to take out the 6speed and put in an automatic? It would be nice not to have to worry about a missed gear or the flywheel coming up through the floor . I just don't think the tremec 6speeds can handle a 500rwhp vette for even 1 day at the track,nevertheless an entire season. Any comments would be appreciated. thanks! Greg O.* Your PCM has to be replaced or reprogrammed to control the automatic .... and the wiring has to be added for the PCM to tranny connections
* You have to add a tranny cooler to your radiator (or a seperate cooler) plus all the plumbing ....
* Console changes for the different shifter, plus cables for the START key interlock and the shifter to tranny cable.
* Wiring for the START interlock system (since you will no longer have a clutch pedal .....
And more ...... and all to put in a 4L60E that without Torque Management would fall apart as fast as your T-56 (if not sooner).
I'd look into upgrading your current transmission to handle your horseppower ... WAY cheaper and easier .... companies such as RPM offer upgraded componenets for high hosepower Corvettes .....
http://www.rpmtransmissions.com
May I ask why you want to swap
