C6 Zo6 Shifter In C5
Old May 26, 2008 | 04:40 PM
phil068's Avatar
phil068
Default C6 Zo6 Shifter In C5
I purchased a c6zo6 shifter from a member here on the forum. I assumed it was a complete setup. It was the angled shifter handle with shift ****. It doesnt have the bottom piece attatched to it. Is this bottom piece the same as the stck c5 unit? It looks the same in the pics I have seen. I know it will fit, but am wondering if I would be better off buying a complete new unit. I want to get the most possible benifit from installing the new shifter. Guess I should have bought it new in the first place. Any info would be apreciated. Thanks
Old May 26, 2008 | 05:21 PM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
Hi.. I installed a complete C6 Z06 shifter assembly in my 00 coupe and the difference is quite noticable from the stock C5 unit... I don't think you'll get the full beneift(if any) form installing just the C6 Z06 handle..
IMO...
Old May 26, 2008 | 06:36 PM
Independent1's Avatar
Independent1
St. Jude Donor '08
^^You want the complete unit. You can get them for a great price from Gene at
http://www.gmpartshouse.com/
I have one in my car and it is great.
Old May 27, 2008 | 05:03 AM
dieseldave56's Avatar
dieseldave56
Default There is a difference................
The C6 Z06 shift box you are referring to mounts more more solidly than the C5. The C6 Z06 has hard plastic bushings and the C5 has rubber bushings[IMG][/IMG] DO NOT look at the shift handel assembles in the picture!!! The shift box on the left is the C6 Z06 . Take note that the two top mounting , located on each end of the shift box are lower than the C5 Z06 on the right. All this does is give you a firmer feel. The two boxes are indentical in everyother way.
Old May 27, 2008 | 10:21 AM
AMRAAM's Avatar
AMRAAM
I did the same thing last year. I bought a shifter from Ebay, not knowing it was just the handle. It was an expensive lesson. I used it anyway because i like the look of the handle better than the stocker, but there is little, if any performance benefit
Old May 27, 2008 | 11:04 AM
dfurnas's Avatar
dfurnas
For looks it will be a lot better in my opinion. Yes you will be better off buying the complete unit from gene. Do that and I recommend buying a c6 "short" leather boot from MAM, the stock leather boot just doesn't look very good to me! There are many companies that sell them on this forum! I feel its the best mod i could have done, and for the price factor its a no brainer!
To C6 Zo6 Shifter In C5
