belt or pulley squeak?
Old May 26, 2008 | 09:32 PM
borisshnitkin's Avatar
borisshnitkin
Default belt or pulley squeak?
i hear a squeak when i go over 2000 RPM, i bought a belt lubricant and it kinda helped but it comes back. what can it be?
Old May 26, 2008 | 09:43 PM
der451b's Avatar
der451b
How old is your C5 belt?
If belt is old , rubber is getting hard, then Belt is noisy. New belt , rubber is soft, no noise until it getting old.
Old May 26, 2008 | 10:37 PM
borisshnitkin
i think it might be the original belt? how much labor is there to replace the belt? or can i change it myself
Old May 26, 2008 | 10:48 PM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
I did mine about 2 months ago with the help of the thread below .Post #2 & #10 provide the detail you need
http://forums.corvetteforum.com/show....php?t=1952764
Old May 26, 2008 | 10:59 PM
DeadFred's Avatar
DeadFred
St. Jude Donor '08
Im currently having the same problem.
Old May 27, 2008 | 12:07 AM
c5mancan's Avatar
c5mancan
Cruising
Replace your belts but also clean and regrease your pulleys if the bearings are good/works everytime..
Old May 29, 2008 | 09:53 AM
borisshnitkin
it was the belts!! i bought the gator ones and now its gone. Very quiet like everyone says. so if anyone does have a squeaky belt def change it with the gator ones. This forum is great!!!
To belt or pulley squeak?
