HVAC Fan Speed Wird After Dim Display Fix
Old May 27, 2008 | 07:24 PM
indieaz's Avatar
indieaz
Default HVAC Fan Speed Wird After Dim Display Fix
I re-soldered some bad solder joints to fix my dim AC control display. Display works great now, but fan controls are wacky. When increasing my fan speed and decreasing about half of the time the display will show an additional bar for the fan speed (or one less if decreasing) but fan speed won't change.
Also, a few times i've increased my fan speed by multiple settings (ie from 2 bars to 5) and no change...then when i DECREASE fan speed one notch (4 bras now) fan speed will suddenly increase. Same goes with decreasing the speed down multiple settings.
The other oddity was at one point my AC suddenly switched to dash/floor mix and i had to set it back to dash only (setting this works fine...but strange that it mysteriously changed on it's own while driving).
One other oddity...occasionally when i turnt he AC on the fans won't kick on at all, and i need to tamper with the normal/recirulate settings or fan speed a bit in order ot get the fans to come on at all.
Any ideas?
Old May 27, 2008 | 09:08 PM
Mr.TT's Avatar
Mr.TT
St. Jude Donor '10, '15-'16
Generic advice, but it certainly seems that you are shorting something out. My only advice is to open the unit back up and see if there are any solder blobs crossing over anything it shouldn't.
Old May 27, 2008 | 09:15 PM
indieaz's Avatar
indieaz
I took it out yesterday and there were certainly two blobs of solder that could have been shorting things out, i cleaned those up. Maybe I didn't clean them off enough, if no other ideas come up I might take it back out this weekend and try again.
Old Jun 15, 2008 | 08:31 PM
Sonnynme's Avatar
Sonnynme
Cruising
Thats funny, I did the same thing last week and am getting the same results with my fan speed....most of the time it doesn't work at all. I did close the hood a little harder than I would like to have and it started working for awhile but now I can't get the blower on at all. One little oddity, a few weeks ago I turned the AC on and the blower started sounding like a crazy woman screaming....I turned it off and then back on and it stopped....hasn't done that since. I know there were no stray solder trails when I re-soldered them so I know that can't be the problem. Does any one know if there is a fan relay for these. I'm thinking that might be it. Haven't checked any codes yet either. But sure could use some help on this one, thanks in advance.
To HVAC Fan Speed Wird After Dim Display Fix
