Dynapack vs Dynojet?
Old May 28, 2008 | 12:40 AM
JerryX's Avatar
JerryX
Default Dynapack vs Dynojet?
I've dyno my 01 Z with an intake and tune and it went 357rwhp on a Dynapack. Now I was told a Dynapack read about 5% lower than a dynojet. Which one is more accurate?
-Jerry
Old May 28, 2008 | 10:41 AM
J.R.'s Avatar
J.R.
Jerry,
I just did my car with Dynapack and then 4 days later with Dynojet.
The difference was 2.5 HP or 0.7 percent.
I also had a friend use the same Dynapack and then travel to Ohio and the Dynojet there showed a 3 HP difference or in his case 0.6 per cent difference.
In both cases the Dynapack showed the higher number. I was really impressed and didn't expect this close a correlation.
J.R.
Old May 28, 2008 | 12:36 PM
Tony Mamo @ AFR's Avatar
0Tony Mamo @ AFR
Former Vendor
Originally Posted by J.R.
Jerry,
J.R.
Thats good info and spot on IMO....(Ive been on both style dyno's many times).
If you have reasonably lightweight rims and tires (like for instance a factory 10.5 inch wide Z06 rim....say total weight with rubber slightly less than 50 lbs) a dynapack will be very close to a DynoJet in terms of recorded power output. If you have an aftermarket wheel tire combo that has some heft to it (approaching 60 lbs) the DynoJet would definately read lower because that combo will be robbing some power trying to accelerate the heavier rim/tire combination. A Dynapack dyno on the other hand is bolted directly to the hub so the variable of the rear tires mass is completely negated.
Bottom line is both dyno's read very similar IMO, but in some cases the Dynapack might give you a slightly friendlier number. Now if you dyno with ET streets and a lightweight rim (total rim/tire weight around 40 lbs) you may actually dyno higher on the DynoJet.
When the smoke clears there probably isnt plus or minus 10 RWHP between them. The real key is repeatability and always using the same dyno to evaluate any mods or changes to the vehicle you have made. Every dyno reads a little different....even dyno's from the same manufacturer. Personally I like using the hub style dyno as it feels alot safer and more secure at high speeds compared to the same situation with your tires spinning 150 MPH on the drum (car is alot less busy feeling during the pull)....and for tuning unless the DynoJet is a load cell type the Dynapack has advantages there as well.
Hope this helps....
Tony
Old May 28, 2008 | 01:20 PM
TM-Z06's Avatar
TM-Z06
FYI.....
My car did 417rwhp on the dynojet and 421rwhp on the Dynapak........the same 2 machines and shop that you're dealing with.
Old May 28, 2008 | 03:20 PM
JerryX's Avatar
JerryX
Sweet! Thanks for the info.
-Jerry
Old May 28, 2008 | 03:31 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
We have owned a dynojet 248 for years and now we are using a Dynapac. Its strange but the medium to lower hp cars read a lot lower on the Dynapac. The higher hp cars seem to be pretty close with our Dynojet numbers. As far as tuning capabilities, there is no comparision.
Old May 28, 2008 | 09:55 PM
Today's problem is..'s Avatar
Cruise-In VI Veteran
St. Jude Donor '09
My shop uses a dynapack also, and we have run into the same problem. Big V8 cars dyno about the same as anywhere else. Its the guys coming in with the 2-300hp cars that wind up getting the really low numbers.
Old Jun 19, 2008 | 05:11 PM
Synergy Motorsports's Avatar
0Synergy Motorsports
Former Vendor
Its all about how you spin a set of 3200lb drums on a Dynojet. This is where the difference lies.
There is no tuning comparison to the Dynapack, it does not get any better.
R
Old Jun 19, 2008 | 07:56 PM
bcseitz's Avatar
bcseitz
Can anyone post pics of a car on the Dynapack hub style dyno. I've never seen one. Thanks
Old Jun 20, 2008 | 12:11 PM
Cruise-In V Veteran
Here ya go
__________________
Home of the Fastest Supercharged C5 8.4 @ 158mph
Home of the Fastest Supercharged IRS GTO 9.0@ 155
Home of the Fastest Supercharged C6 9.7 @ 143mph
Proud Sponsor of the ECS Corvette Challenge
http://www.corvettechallenge.info
609-752-0321
Old Jun 20, 2008 | 08:26 PM
bcseitz's Avatar
bcseitz
Thanks Chris! I'll be darned! I didn't expect to see anything as portable as that.
What is the rear of the car supported by? Something like jackstands or a transmission jack under the crossmember? I've got to believe whatever it is it must be secured to the floor as well as the car?
To Dynapack vs Dynojet?
