Diff makes funny noise
Old May 28, 2008 | 01:17 AM
STEEL's Avatar
STEEL
Default Diff makes funny noise
My diff seems to be making a swooshing sound when Im in gear and turning, but only one im in gear. I have a 99 FRC stick shift. Does this mean my diff is craping out? I changed fluid and put an additive and that didnt help. And if it is going out god forbid I have to change it what is a good beefed up one I can get because I plan on going forced induction later on, and I want one that can handle the power, what would be a good one to get???
Old May 28, 2008 | 08:07 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
If you want a good beefed up one, RPM transmission builds a nice one. Same with DTE. Make sure you get the DTE brace too.
Old May 28, 2008 | 08:39 PM
jmiller's Avatar
jmiller
I had the same issue. I replaced with gm fluid and 1 bottle of anti slip. I added a second bottle and now I have no noise.
Add another bottle of anti slip and see if that fixes it.
Old May 29, 2008 | 12:58 AM
VetteTech81's Avatar
VetteTech81
I would try it.. did you run synthetic or regular gear lube?
Old May 30, 2008 | 02:59 PM
STEEL's Avatar
STEEL
I used redline synthetic fluid and there additive for the posi track and still didnt work is the GM fluid better?
Old May 30, 2008 | 07:21 PM
VetteTech81
I've been using non synthetic with the regular GM additive and have not had one complaint.. so thats what I stick with. If a customer wants synthetic used we will. However I caution them as I have heard many complaints of clutch "chatter" while running synthetic.
-=Rick
To Diff makes funny noise
