?WHY? am i installing this cam by myself
If you have done a cam please give me some motivation..
i have the hood off, the radiator, and fan out.. It looks so much easier with the a/c radiator out, but ls1 says to leave it in
what a pain in the butt
thank
Just wait till you do your 3rd or 4th solo cam swap
next time leave the hood on
get the crank pulley rem'l tool, search gm crank pulley remover on the auction site
get the cp installer from ls1tech
use 5/16" rods from lowes to keep the lifters in place
if the hood was ON, that would be a good place to tie the ac cond to
post questions, we will answer
hopefully you consulted your tuner on a good grind
just to be clear, it's the a/c condensor, basically it looks like a radiator, don't touch the compressor
I've done 3 swaps. 2 on mine, 1 on a buddy's car
Keep those spirits up and have a cold one
As i recall my issues were as follows:
waterpump removal required a lot of patience
power steering pump required a lot of patience
steering rack removal required a big (very big) pry bar
I lost a lot of skin on the edges of the new heads (razor sharp)
A year later, I decided to put on an underdrive pulley while i was changing out the exhaust. Everything was much easier/quicker and I had the water pump/power steering off in a matter of minutes.
I keep a photo album in my rear storage compartment, the feeling of completing the project yourself is worth the loss of skin! TAKE YOUR TIME!!
