O2 sensor switching codes help
Old May 28, 2008 | 05:19 PM
slayer6x6's Avatar
slayer6x6
Default O2 sensor switching codes help
Well Im getting a flashing check engine light, so I hooked up my graphing scanner to check it out. I have B1S1 and B2S1 switching codes. When the car is warmed up, both O2 sensor voltages are around 50mv, but when crusing at a steady throttle the voltages are peaked at a steady 950mv. Any ideas on where I should go here?
