injector ?
Old May 29, 2008 | 06:21 PM
z06 hellcat's Avatar
z06 hellcat
Default injector ?
i was wondering if i could benefit from larger injectors, i have a 04 Z with these mods,vararam,highflow airbridge, dynatech longtubes,x-pipe, hi-flo cats, comp cam 231/234/643/598/ 111 lsa, prc dual springs, titanium retainers, ls2 timing chain, 426 rwhp 400 pounds torque,thanks in avance!
Old May 29, 2008 | 06:34 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
You won't benefit power wise until your stock 29# injectors are maxed out (which you are probably close). I'm sure you have a tune, so your tuner should have told you if you were maxing them out. As long as your car is getting the proper amount of fuel to keep the AFR where the tuner set it, there would be no benefit. Bigger injectors would still put in the same amount of fuel since your AFR hasn't changed, just at a lower duty cycle. Plus, with larger injectors, you would have to have your tune re-done. I would save the injectors for when you put heads on it.
