I want to go with a BBK SSI and 85mm throttle body. The questions I have are...
- Will I need any separate wiring to make the change from stock?
- If the throttle body fits a 98-04 F-body will it fit in my 97 C5?
- What can I honestly expect for gains with headers and CAI only?
Thanks guys
If you're asking if a throttle body that fits an F body will also fit a C5, the answer is no. The F body throttle is cable actuated, not so for the C5. BBK does however make a C5 specific throttle body IIRC in which case you shouldn't have to make any wiring changes.
Depending on the headers/CAI chosen, I would reasonably expect somewhere in the 20-25hp gain over stock.
Thanks guys for all the help. I had one of my vacuum lines pop off and lost control of my a/c. Thats just not fun in South Texas so I figured I would upgrade while I was at it.
