I have dual climate control and the ac runs cold on drivers side and hot on passengers side no matter what the passengers side temp is set at??
can anybody help with this one ??
Sounds like a temperature door actuator! You'll need to get it diagnosed, but that's probably it! There is one on each side I believe.
Gene's right. You can try resetting the HVAC and see if the actuators will act right. Pull fuse #27 in the pass footwell for 60 seconds and replace it. That should cause the system to reset.
Mine did the same thing and all I had to do was shut off the engine and restart. Simultaneous Cold on driver and hot on passenger was wierd!
Do a search - very common issue. The likely causes are:
- Driver's actuator door gears are stuck. Try resetting the HVAC system as noted above by pulling fuse and letting unit reinitialize to try to reset door open/close limits. If that doesn't work, then door motor may need to be replaced.
- Some have commented that a system low on refridgerant can cause this - may need a recharge.
