QA-1 Adjustable Shocks Good/Bad? at Drags?
Old Jun 1, 2008 | 11:01 AM
soblad's Avatar
soblad
Default QA-1 Adjustable Shocks Good/Bad? at Drags?
I've been looking for hours on the CF, and can't find out how these are working on the drag strip, vs stock Z06 shocks I have the 2002 with 403 rwhp.
Have you installed the QA-1's after getting a good base ET then tyied them out? Hoo's the manufacture?
Help!
Old Jun 1, 2008 | 01:57 PM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
I have QA1's, but I race on road courses not drags. What I like about the QA1's is you can dial-in the firmness you want. I would assume that at the drag-strip this will be an advantage wherein you can soften the rear to provide the desired weight shift off-the-line.
Old Jun 1, 2008 | 08:34 PM
soblad's Avatar
soblad
Default Thanks for the info.
Thanks, Sully
Ya that's where I'm going to use them but tring to figure out if the
$650. worth it. All I need is more problems with less money
Old Jun 1, 2008 | 08:50 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
The QA1's are some of the best shocks you can buy. They are a great all around shock that can be used street/track/strip and all you have to do is turn a ****. I have them on the C3 drag car, my C4 race car project, and contemplating a set on the C5. Of course i get a pretty good deal on them as well
Old Jun 1, 2008 | 09:50 PM
K RIPPER's Avatar
K RIPPER
I bought my 03 Z/06 new and I drag race in the corvette challenge 'the MPH was always there but the et's were all over the board, I tried all my tricks I've learned over the years(add weight add to one side than the other , shift weight side to side ,lower,raise ride height ect. ect. ect.)much more than I care to admit. Then as i stopped or lessened tire spin another totally unacceptable monster reared it's ugly head wheel hop at times severe so I bit the bullet and bought QA 1's I admit it was a tough decision a thousand bucks for four shocks but son of a b#%#* those suckers flat out worked.I picked up 2 to 3 tenths short times went from 2.00 to mid 1.7 best et prior 12.20 ,and I've gotten into the elevens and I've only started to play. And is sooo cool you can adjust for the street ride you want... going out W/ the old lady set 'em down for a soft ride spirted driving set 'em hard drag set front soft back hard no bite at the track?set the back softer the possibilties are endless so am I happy with them? yes I am, but a grand for a set of shocks is a tough nut to swallow
Old Jun 2, 2008 | 10:28 AM
soblad's Avatar
soblad
Thanks, K RIPPER
What helps a lot! Do you half to jack the car up or get on a hoist to adjust?
When you did the fronts did you change the sway bar in any way, or disconnect it?
Old Jun 2, 2008 | 10:59 AM
robz's Avatar
robz
Help!
You don't need them at your power level.
I have cut 1.42's on the stock shocks with et streets and rwhp between 400-420.
Some of the c6Z guys feel they help with wheelhop.
Old Jun 2, 2008 | 11:25 AM
soblad's Avatar
soblad
Ok, What RPM are you come out at the light with the DR's??
Old Jun 2, 2008 | 11:39 AM
K RIPPER's Avatar
K RIPPER
On C5 no jack up to adjust but you have to lay un ground to adjust plus on fronts adjuster **** on inside,& for ease of acess turn wheel hard right then hard left to adj. each side rear adj. **** on inside.QA1 tech. (Dave) recomend disconnect sway bar for best results (I didn't) R&R on rears no prob.on fronts tie down shocks W/tie wraps or wire gas charged shocks expand when disconnected & cannot get shock out .reuse stock bushing F&R I didn't reuse front plastic spacer(?) before install stand shock right side up push full open & close (elim.air bubblesbut prob. not necessary but can't hurt)I marked lower control in rear direction to adjust but **** on inside & outside(adjuster) it gets confusing I found as the **** gets easier to turn you are going toward the soft setting , harder to turn going to hard setting I recommend buuy & install al 4 same time but if $ is a prob. buy fronts first GOOD LUCK!!!!
Old Jun 2, 2008 | 11:59 AM
soblad's Avatar
soblad
ROBZ,
Ok, can I ask what RPM's you rev to on the line to get a 1.4 #
Old Jun 2, 2008 | 01:45 PM
robz's Avatar
robz
ROBZ,
I wrote an article on launching a c5Z. It is in the Corvette challenge web articles somewhere.
Basically with et streets I used to launched from 5500-6500 depending on track conditions, etc.
If you are running et street radials you can probably launch around 5000rpms if you do a good burnout.
It all depends on how serious you are about achieving the best et you can with the car understanding the risks of breakage.
Tell me your specific setup and tires and I'll put you in the ballpark.
Include your goals with the car (ie. Whether your looking for an 11 second pass or 10 second pass).
I'll pull up a video if you like.
Old Jun 2, 2008 | 01:54 PM
robz's Avatar
robz
Here's a video of an 03Z06 with around 410rwhp and stock shocks on et streets.
Launch ~ 6000rpm's
View My Video
Old Jun 3, 2008 | 11:12 AM
soblad's Avatar
soblad
ROBZ,
Neat video, really was just curious more than wanting to do that high of a leave. I live 100 miles away from my nearest strip so breakage at 8-9 PM is not a possibility or an allowable item.
I've been leaving at 3-3500 RPM using Rangers techniques for about two years (may be 60 runs) I have a 12.70 average ET, 2002 Z06 Corvette. It don't out at 403/390 torque. My 60' times usually 2.10 don't make sense. Got a couple of 1.94 & 1.96's in at 388 rwhp. But now with 403 rwhp and MT's (new) not old hard ones 2.10 (1 run) the rest (4) at 2.21+
Tuner felt clutch gone, I decided time to go automatic doing a RPM level 4 at this time. Very expensive but I'm a senior not to much more race time left. Hoping for 1.75 60's and low 12's as far as my goals. Will be out racing in the all Corvette races Sunday the 8 th. with no test time. But I'm convinced with no shifts missed, and no water on the line I'll take home the King of the Hill"
Thanks, for your help!
Old Jun 3, 2008 | 11:42 AM
robz's Avatar
robz
ROBZ,
The 60' times don't make sense.
Make sure you heat them up with a good burnout and I would start around 20 psi. That should give you 1.7x's.
Old Jun 3, 2008 | 12:17 PM
BitViper's Avatar
BitViper
Funny thing is that over on the LS1 boards they all bad mouth QA1's
I have no real input or experience with the product..Im just amazed how diffrent things are between "cultures".
Ive always thought the if the QWA1's were such a bad choice how could they keep selling them Obviously they do the job and do it well....Intresting
Old Jun 3, 2008 | 01:13 PM
NASAblue's Avatar
NASAblue
I have QA1 coilovers and love em
very high quality piece!
Old Jun 3, 2008 | 01:55 PM
soblad's Avatar
soblad
Yes I did that, did a break burn out. MT says very little burn out after
3rd or 4th run.
I started at 20lbs then went to 16 lbs. Best 60' was 20 lbs. with only 2200 RPM's (a 2.08 was my second pass).
Will let you know after the week end's race.
To QA-1 Adjustable Shocks Good/Bad? at Drags?
Old Jun 3, 2008 | 01:56 PM
soblad's Avatar
soblad
Thanks!
Old Jun 3, 2008 | 03:03 PM
robz's Avatar
robz
3rd or 4th run.
Don't be afraid to do a decent burnout EVERY time. It won't hurt and will likey help.
If your auto now and can't come out higher than 2200 then you should air up the tires until you don't bog. You'll get it.
Old Jun 3, 2008 | 04:02 PM
VIPERBLUELX's Avatar
VIPERBLUELX
Launch ~ 6000rpm's
View My Video
Very impressive, can you tell me a little more about that setup you used to achieve that 60ft? What size tires and wheels? Did you have a hardened output shaft and DTE brace? 3.42 gear? What clutch?
