would appreciate help with an electrical schematic.
I fixed the display my HVAC on my 2000 a little while ago. just needed to resolder a few 2M components, however in my haste to fix it, I broke one of the flat components. The display is still bright, but only half the LED works. So I need to replace the component. The components are the ones labeled with the "241"
Does anyone have a card schematic for the HVAC unit? or even a Newark.com (or similar site) part number?
any assistance would be appreciated.
this is the card I have.
Isn't that 240 ohm? Should be 24 with 1 zero. If you have enough space, you can use a standard ceramic resistor too and just get it at radio shack or some local electronics supplier. The resistor would only need to be 1/4 watt. The bands will be red, yellow, brown, plus your tolerance bands which won't matter in this case.
