Still having problems with my A/C Control LCD Screen. Please help!!
Old Dec 20, 2001 | 04:37 PM
Fivo Killer's Avatar
Fivo Killer
Default Still having problems with my A/C Control LCD Screen. Please help!!
For some odd reason, the LCD unit on my HVAC worked when I started the car this morning. Then after about 5 minutes, it started to fade away. After I got to work the LCD's were all but barely lit. So I dont know if it is a short in the LCD part of the unit, or perhaps a bad connection somewhere. It would be ashame to have to buy an HVAC unit for it if it is just a short somewhere. Is it possible to take them apart if you know what you are doing, or if you have electrical engineers for friends???? Please help, this is getting to be a pain in the butt!!
Old Dec 20, 2001 | 07:35 PM
99 The Hard Way's Avatar
99 The Hard Way
Default Re: Still having problems with my A/C Control LCD Screen. Please help!! (Fivo Killer)
This happens to a lot of 97-98s. My display did the same thing as yours. I got a used one off the forum & no more problems. I've been told by many that when they do this, you can't fix it. It is an easy swap. The new ones are expensive, but i found my used one for $50. SCOTT
