Lighting problem.
Old Jun 3, 2008 | 11:03 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
Default Lighting problem.
Hey guys I have a quick question for y'all.
When I turn on my headlights, they pop up no problem, they are on but the taillights, rear markerlights, foglights and instrument cluster lights don't go on. They all work fine so I believe it's a micro relay, does anyone know which micro relay controls that function?
TIA.
Old Jun 4, 2008 | 12:09 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi themonk -
Have you checked the two fuse panels?
There are two - one under the hood near the battery, and the other is behind a kick-panel in the passenger footwell.
The underhood panel contains several spare micro-fuses, and both feature a complete diagram of the circuits.
I was surprised to find out very recently that each of the headlamps has it's own fuse - hi beam left, low beam left etc.
Both panels also contain many relays, also marked. If you are handy with a volt/ohm meter, you should be able to ferret out the problem if it is a relay.
If this does not pan out, check out the great electrical troubleshooting tips from Bill Curlee in the stickies.
best regards -
mqqn
Old Jun 4, 2008 | 12:46 AM
themonk's Avatar
themonk
Thanks, I'll give 'er a go.
To Lighting problem.
