Radiator Drain (Petcock)
Old Jun 4, 2008 | 10:56 AM
khaggins's Avatar
khaggins
Default Radiator Drain (Petcock)
I am trying to drain my radiator fluid. There is a plastic petcock that must be turned to drain the fluid. What device / tool is used to turn this petcock. Also can it be replaced with something more durable? Help! I have a 2001 ZO6.
Old Jun 4, 2008 | 10:59 AM
slothy's Avatar
slothy
I believe a 1/4" ratchet fits in there
Old Jun 4, 2008 | 11:02 AM
khaggins's Avatar
khaggins
thanks. I tried that but it does seem to work properly. I keeps pushing out when turning.
Old Jun 4, 2008 | 11:11 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi khaggins -
http://forums.corvetteforum.com/show....php?t=2042498
best regards -
mqqn
Old Jun 4, 2008 | 11:20 AM
khaggins's Avatar
khaggins
Originally Posted by mqqn
Excellent! I got it. Twist and pull. I thought it was scew out. Thanks!
Old Jun 4, 2008 | 11:37 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
A short 1/4" drive extension on the ratchet handle works perfect.
Also,you only need to open the petcock 1/4 turn.
To Radiator Drain (Petcock)
