opinions on cam change
Old Jun 4, 2008 | 03:01 PM
DPG's Avatar
DPG
St. Jude Donor '06
Default opinions on cam change
long story short, my old cam is gone and i now have the opportunity to go bigger. but i have a few questions for the cam experts.
old cam: 232/234 112 .598/.593
made 417rwhp with basic bolt ons
my question is i would like to squeeze some extra hp out of the motor but not sacrifice driveability that i had with this old cam
i was looking at the texas speed cams and saw the magik stick 4 and 3 i see that the 4 has a crazy lift on the intake im going to assume. would these cams be noticably worse at idle and low rpm driveabilty than what i had previously? the 4 would have to be on 112lsa and the 3 on 113 is what i was thinking as far as lsa
any input would be great. i know that tunning can fix most driveabliity issues. but i dont want this to be a nightmare for the tuner to tune
Old Jun 4, 2008 | 03:13 PM
black98c5's Avatar
black98c5
Dave, You should also consider the G5X4. I wouldn't worry too much about drivability since it's really all in the tune. My G5X3 112 lsa drives like stock but with a massive lope of course and sick power . Had I known it would be this streetable, I would have went with the G5X4. This is in a A4 by the way
Old Jun 4, 2008 | 03:16 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
^ Correct. It is all in the tune
Old Jun 4, 2008 | 03:27 PM
DPG's Avatar
DPG
St. Jude Donor '06
hmmm....what kind of power did you put down
Old Jun 4, 2008 | 03:31 PM
DPG's Avatar
DPG
St. Jude Donor '06
anyone know the cam specs on the x3 and x4?
Old Jun 4, 2008 | 03:33 PM
black98c5's Avatar
black98c5
stock 853 heads, stock ls1 intake manifold, 3:73's/SS3600 stall, I put down 370+ on a mustang Dyno. It would be at 400+rwhp on a Dynojet. Since then I added the LS6 manifold. You should put down some sick numbers.
Old Jun 4, 2008 | 03:35 PM
slothy's Avatar
slothy
I have the MS4 and no issues with idle - i have very little and i mean little surge around 1500-1800rpm ish area. I had mine installed/tuned by roadrebel.
haven't dyno'd it yet
Old Jun 4, 2008 | 03:44 PM
DPG's Avatar
DPG
St. Jude Donor '06
i assuming the ms4 is the magik stick 4 cam?
also, where you able to use the stock length push rods with that cam? I have stock length hardened ones and dual pat gold springs.
Old Jun 4, 2008 | 03:45 PM
DPG's Avatar
DPG
St. Jude Donor '06
thanks
Old Jun 4, 2008 | 03:47 PM
slothy's Avatar
slothy
yes ms4 = magicstik 4
stk length (tsp ones) rods with duals springs is what i used.
Old Jun 4, 2008 | 03:50 PM
DPG's Avatar
DPG
St. Jude Donor '06
hmmm now you have me really interested. thanks for the info
keep the info coming guys. its good so far and will really help with a decision. thank you for the info so far
Old Jun 4, 2008 | 03:53 PM
slothy's Avatar
slothy
ill try and get a vid/sound of the cam lope - it makes me smile when sitting at stop light lol
Old Jun 4, 2008 | 03:58 PM
DPG's Avatar
DPG
St. Jude Donor '06
it would be much appreciated
here is my old cam
Old Jun 4, 2008 | 06:53 PM
TM-Z06's Avatar
TM-Z06
You'd pick up more hp/tq doing the heads and a ported FAST intake as opposed to swapping the cam. Just my .02
Old Jun 5, 2008 | 10:20 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Dave bro, I will give you a call sometime today. Let's talk abougt cam size...some of those bigger cams are great, but they dont start making good power until 5k or above...I think one of the things you liked about your old cam was at those specs, you were making power pretty early in the powerband.
man, i am off line for 1 day and miss all this
Old Jun 5, 2008 | 10:26 AM
slothy's Avatar
slothy
well i got video, but seems sp1 on vista doesn't seem to like the camcorder now
ya as frank said power on the ms4 cam seems to kick in around 5k
Old Jun 5, 2008 | 10:43 AM
DPG's Avatar
DPG
St. Jude Donor '06
good point guys. i am taking a closer look at the ms3 right now. i am waiting for texas speed to open up so that i can maybe talk to someone about it.
To opinions on cam change
black98c5's Avatar
black98c5
Dave, just get a monster cam with some 4:10's and you have the best of both worlds
Old Jun 5, 2008 | 11:12 AM
DPG's Avatar
DPG
St. Jude Donor '06
you can guess who the other person was who told me that besides you. Al, as much as I want to go big and go big with the gears. its just not in my near future right now. thanks for putting the idea in my head though
thanks for all your help guys. i went with the texas speed v3 torquer. its supposed to have a better mid range and a couple extra ponies than my old cam. i'll post up results once i get em. i'll be a while
Old Jun 5, 2008 | 11:15 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
Dave, here are my cam specs, and you've driven my car before. This might help put things into perspective. I consider my cam middle of the road. You want to go bigger anyway, but just to throw it out there...
113 LSA 228/232 .590 .595
My power kicks in at about 3300-3500
