Torque Tube Bushing / coupler (possible m3 replacement?)
Old Nov 1, 2008 | 11:14 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I just pulled a 2003 Z06 TT apart this week, had a brand new BMW coupler ready to go in, the OE GM unit looked mint up front, didn't touch it
a solid LG coupler went out back
Save your self some time and get a T45 Torx plus from a good source like your snap-on truck
a T50 will work, but it's not correct
Side by side, the GM vs. BMW do NOT look the same, .02
Old Nov 1, 2008 | 03:13 PM
Rconce01's Avatar
Rconce01
Originally Posted by Mike94ZLT1
I am interested in the stiffer 10mm ones as well!
he'll pm you with the info if not i'll forward it to you
Old Nov 1, 2008 | 03:15 PM
Rconce01's Avatar
Rconce01
do you mean it had a bmw coupler in there or that you are going to put a bmw coupler in?
Are you putting the stiff m3 m5 coupler or the soft one i put and then tore up in 20 k miles
i am definitly going to put the lg aluminum one in the rear.
Old Nov 1, 2008 | 03:18 PM
Rconce01's Avatar
Rconce01
ummm well no track but i drive alot of highway and city daily and i take out all my issues on the poor car.
Its cheaper than a psychologist and funner too! the downside is the repair time and the effort.
When i took the tranny in 2 days ago to fix up the issue with the third gear the tranny guy couldn't beleive i went though a "z" pack 3rd clutch pack in 20 k miles
Originally Posted by tstar
20k??? Wow that isn't much longevity! Are you stock or track alot??
Old Nov 2, 2008 | 12:33 AM
Max01GreenMachine's Avatar
Max01GreenMachine
2017 C6 of the Year Finalist
Cruise-In VI Veteran
I have a pair of stock 2001 12mm GM couplers that are in mint condition. I replaced mine with two LG Aluminum couplers at 45000 miles, pre all of my power adders. If you want pictures I have them. $50 you can have both.
PM me,
Max
Old Nov 3, 2008 | 09:39 AM
Rconce01's Avatar
Rconce01
Did you do two solid couplers? Doesn’t vibrate?? I use 10mm so yours won't work for me.
Does anyone know if the solid ones exist in 10mm size?
PM me,
Max
