High/Low beams on the same time
Old Jun 4, 2008 | 05:09 PM
LT1vette's Avatar
LT1vette
Default High/Low beams on the same time
Is it possible to "fix" GM's screw up of turning off the low beams when the highs come on?
Do I just need to run a relay to "fix" the problem? Does anyone have a wiring schematic to do this ?
THX
Old Jun 4, 2008 | 05:17 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi LT1vette -
Using the search feature, I found......
http://forums.corvetteforum.com/show...post1560380857
and....
http://forums.corvetteforum.com/show....php?t=1698467
I also remember that someone here set it up so the the fog lights would remain on with the high beams as well.
Good luck!
best regards-
mqqn
Old Jun 4, 2008 | 06:24 PM
jrprich's Avatar
jrprich
search All 4 headlights on high
I used his multi relay instructions and it turned out great. I can now have all 6 lights on at a time
To High/Low beams on the same time
