A4 Shifting
Old Jun 4, 2008 | 07:18 PM
C5Pat's Avatar
C5Pat
Default A4 Shifting
I just installed 3:42s gears, I reprogramed for the new gears everthing seems fine, except when cruising at around 70MPH in 4th(OD) when I kick it down, it will down shift fine and then go back into OD as it should. Then it will down shift again for a second, What gives??
Old Jun 4, 2008 | 11:42 PM
OhioC5's Avatar
OhioC5
What program are you using? I have a real nice 3:42 tranny tune for Hptuners.
Old Jun 5, 2008 | 12:47 AM
97C5owner's Avatar
97C5owner
Did the gears wake her up alot? I just bought one and am a little hesitant to put it in.
Old Jun 5, 2008 | 01:02 AM
wayne2seater's Avatar
wayne2seater
I just bought a a set of 3.42's for my car and hope to have them in this weekend, I've been hearing about different problems that some people been having with the programing side of it. I'm also tring to learn all that I can so I will be ready if problems come up.
Old Jun 5, 2008 | 04:33 AM
chaase's Avatar
chaase
St. Jude Donor '12
If you had 2.73's, then it will be an amazing difference. I went from 3.15 to 3.42 and it was okay. A new torque converter will help.
Old Jun 5, 2008 | 08:53 AM
C5Pat's Avatar
C5Pat
I used a Predator tuner, I just entered in the gear ratio and increased the shift pressure 5%. It's works fine except what it does sometimes as I described in my original thread. It just seems the settings are a little sensitive. I was wondering if I should set the shift pressure back a bit????
Old Jun 5, 2008 | 08:54 AM
C5Pat's Avatar
C5Pat
Oh.. you won't be dissapointed!!!!
Old Jun 5, 2008 | 09:13 AM
frodo84's Avatar
frodo84
Uneducated autodidact
I have 3.42s with an A4, also a 3500 Yank converter...you are still running the stock converter? I don't think you'll get your tune perfect with a Predator though. I started with that, then got a custom tune through the Predator vendor...you could do it that way but you'll need to log some data to get it perfect. Just my $.02.....
Old Jun 5, 2008 | 09:25 AM
C5Pat's Avatar
C5Pat
Thanks.... I will call Predator and see what they can do, like I said it's close, may just need some fine tuning
To A4 Shifting
