Help with gas gauge
Old Jun 5, 2008 | 11:12 PM
251's Avatar
251
Default Help with gas gauge
Today, my wife and I drove around with the top down for two hours enjoying the nice weather. When I returned home, the gas gauge read more than when we left. About a 1\8 more. Hmmmmmm? I just new we probabaly burned up aleast a 1\4 tank.
Old Jun 6, 2008 | 12:12 AM
p_dubya's Avatar
p_dubya
Could be that it was stuck in a lower postion when you left and started reading properly as you drove. The C5 has a very common problem of the guage reading low or empty.
Usually running some Chevron Techron (or any good fuel system cleaner) will free it up and get it reading properly.
Old Jun 10, 2008 | 03:46 PM
MRRAZZY2003's Avatar
MRRAZZY2003
There's a kajillion posts on dealing with the fuel gauge issue. Mine (2004 Coupe) quits between 1/2 and a little over a 1/4. Fine on both sides of that. I've tried Techron until I might as well own stock in the company. Top Tier fuel has not changed a thing either and many suggest 1-2 Techron treatments and top tier fuel does the trick. I have to go well out of my way to get Top Tier gas and have done it for several fill ups. Until then, I was running Sunoco 94 - 3 years and no problems - all started last summer.
I give up. I know my cruising range pretty well. Not a chance I'll pay a dealer $100's ($1,000's?) to fix my sending unit(s) to have it happen again? One would think when you spend $45K new, a good fuel measurement system would come with it. GM should be standing behind this one. Embarassing, but it's still a Vette, it's mine, and I'll put up with it.
Old Jun 10, 2008 | 03:48 PM
gray-c5's Avatar
gray-c5
St. Jude Donor '08
Old Jun 10, 2008 | 05:58 PM
rws.1's Avatar
rws.1
Don't just run a couple tankfuls of fuel system cleaner. Switch to a better gasoline...
www.toptiergas.com
Old Jun 10, 2008 | 09:50 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
How many times are you going to tell us this?
http://forums.corvetteforum.com/show....php?t=2045087
Old Jun 11, 2008 | 09:29 AM
jovette's Avatar
jovette
One post should be enough Plus, you might think about posting problems with a C6 in the C6 tech section
To Help with gas gauge
