Good cam for stock heads?
Old Dec 21, 2001 | 09:25 AM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Default Good cam for stock heads?
What would be a good cam to get without any mods other than air filter and long tube headers? I'd like to increase power, but I want it to be a mild increase and throughout the rev range, not mostly in the high RPMs.
Old Dec 21, 2001 | 10:40 AM
jeffh355's Avatar
jeffh355
Default Re: Good cam for stock heads? (Scissors)
I have personally ordered the GM Hotcam, but I to would like to know what others think.
Old Dec 21, 2001 | 11:03 AM
6Speeder's Avatar
6Speeder
My choice, the MMS 218 duration, is mild enough that it works well with stock heads, and great with massaged heads. I saw torque increases from 2,000 rpm up. :chevy
[Modified by 6Speeder, 9:05 AM 12/21/2001]
Old Dec 21, 2001 | 11:13 AM
Nilla Ice's Avatar
Nilla Ice
Stay at or below the 218 intake duration and all should be good. Go with a little higher lift for some added torque.
Old Dec 21, 2001 | 12:00 PM
Scissors's Avatar
Scissors
What's the duration on the GM Hotcam?
Old Dec 21, 2001 | 12:39 PM
123Gone's Avatar
123Gone
And, what kind of HP and torque increase do you get with the GM Hotcam? Also, if the dealer installs it (gulp), perhaps the warranty will not be in jeopardy in case of future engine problems. What do you think?
[Modified by 123Gone, 4:53 PM 12/21/2001]
Old Dec 21, 2001 | 12:55 PM
jeffh355's Avatar
jeffh355
Default Re: Good cam for stock heads? (123Gone)
Damn Guys! I can't find my paperwork on the Hotcam. I was sold on it by this forum so I'm sure someone will chime in here. Jeff
Old Dec 21, 2001 | 02:11 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
This is a previous!
The B1 or the T1 Cam is a good choice. The only difference between the two cams is the lobe seperation angle. The T1 has a lower 112 LSA and will typically produce more low/midrange torque and also make peak hp around 150-200 rpms sooner than the B1. The T1 will idle a bit choppier and not do as well as the 114 LSA B1 during emission testing. Both the T1 and the B1 have passed. As far as peak hp figures, the cams are almost identical. The B1 should make a bit more peak hp, less than 5.
Old Dec 21, 2001 | 10:38 PM
Nilla Ice's Avatar
Nilla Ice
Default Re: Good cam for stock heads? (jeffh355)
something very similar to this.
219/228 525/525 112...good cam for those that want a little of each. It'll idle like a bigger cam, run very good, and not need 7K revs because of the 112 separation. Not good for A4 guys that don't want to pay for real PCM tuning.
Tony
Old Dec 21, 2001 | 11:05 PM
LV's Avatar
LV
Default Re: Good cam for stock heads? (Nilla Ice)
What do you folks think about the Comp Cam 54414-11 with stock heads? .525/.532 216/220 114
Old Dec 21, 2001 | 11:11 PM
Nilla Ice's Avatar
Nilla Ice
Default Re: Good cam for stock heads? (LV)
Will work about 30ish to the rearwheels.
Tony
To Good cam for stock heads?
