weird electrical issues over 220 degrees
Old Jun 7, 2008 | 10:07 AM
blazen 1's Avatar
blazen 1
Default weird electrical issues over 220 degrees
Hello,
I need help with my 97 6 speed. It only has 28k.
Anytime the car goes over 220 degrees (never over heats always stops at 240) the car does weird things electrically.
Sometimes I lose all of my memory stuff, sometimes the tire service monitoring turns back on by itself, sometimes the gas gauge stops working, etc.
All of these things go away after the car has cooled itself back down below 220 and is restarted.
I have no idea where to start or what to look for, so any suggestions would be appreciated.
Thanks,
Greg
Old Jun 7, 2008 | 10:10 AM
Corvette Don's Avatar
Corvette Don
I dont see how the high temps would tie into that, I would check your air dam area in front of the raidator for debries that may be limiting airflow
Old Jun 7, 2008 | 11:29 AM
BlackZ06's Avatar
BlackZ06
Weird ......
Some thoughts .....
1) Have you set your DIC to show battery voltage when over 220 degrees ????? Is the voltage fluctuating and.or dropping below about 12.5 volts ??? It sure sounds like you are getting low voltage and different parts of the car are reacting "badly" to the low voltage.
2) How old is the battery .... maybe it is borderline and the draw of the HIGH speed cooling fans (each has a 30 amp fuse so they draw A LOT) coming on is dropping battery voltage too low.
3) Have you checked the battery connections ... a heavy draw and a bad connection could lead to low voltage in the car.
4) Also check the connections from the alternator that go to the starter and then to the POSITIVE battery terminal ..... CAUTION those connections are HOT at all times unless you disconnect the battery ... so be careful of them.
That's my wild azz guess ... the cooling fans kicking into HIGH are pulling down your car's voltage.
Old Jun 7, 2008 | 05:30 PM
bestvettever's Avatar
bestvettever
Default Electrical Problems
Originally Posted by BlackZ06
Weird ......
Some thoughts .....
Hi, Good advice, I agree, the hotter it gets under the hood the voltage regulator cuts the alt output. Couple that with possible loose or dirty connections, and or a battery on it's way out and you've got the symptoms discussed.
Good Luck
Old Jun 8, 2008 | 12:23 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Yes, all good suggestions. One other possibility is the coolant sensor itself. If it goes bad or becomes erratic, the car practically won't run.
Old Jun 10, 2008 | 03:07 PM
blazen 1's Avatar
blazen 1
Thanks guys those are all great suggestions. I am going to replace my battery.
I had a 2000 c5 and I remember that the battery filled the whole battery tray.
The one that came in my 97 when I bought it barely fills up half of the tray. So my guess is it that even though it is new it just doesn't have the power to run everything under a large load.
I will also clean the connections you guys suggested as well.
Great advice and thanks again.
Old Jun 10, 2008 | 04:15 PM
DPG's Avatar
DPG
St. Jude Donor '06
great suggestions guys. my guess would be that when the high speed fan kicks in, it drains more power and there is your power loss type situation.
To weird electrical issues over 220 degrees
