I have a 99 that I drag race, and I removed the ABS System Completely, Mechanical and Computer. I cannot do a burnout at all now, as the ASR kicks on and bogs the motor. Computer scan shows the timing just hit the floor. The car is Ok other that the burnout. Does anyone have any info on how to defeat the ASR completely?????
The C5's have a TCS system, Traction Control System. Yes, it does work with the brakes, but it also pulsl timing and fuel. No, it can't just be ripped out, you have to do some tune modifications. Get with a tuner and have them help you out. Not sure if I would recomend you to try and tune it out youself if you have never worked with a C5 type system. Or like stated above, turning it off may be all you need.
There is also a active handling system which can also apply brakes.
I would suggest visting the drag race forum here and do some research before removing stuff. You may cause yourself more work than needed. But, then again I don't know what is good to do for drag racing, I like turns LOL...
What kind of times are you doing to justify taking out the ABS??
You should explain exactly what modules you removed from the car and any other things such as tuning you think you have done. Use the correct terms for the modules.
The Traction Control System is part of the ABS system and if you had removed the EBCM it would not be able to request a reduction in power.
Bill
Bill
Very hard to figure out what you did. If EBCM is out no signal should be sent to reduce timing to PCM.
Active handling gyroscope is on passenger side floor next to tunnel. Have you removed pind from wiring harness at PCM for traction control and other items that you removed ??
The car is basically a "Straight Line Street Car". She lives at the Drag Strip, and cruises the streets occassionally. Last year it ran 9.70's at 144 MPH, and this year we needed to reduce weight shooting for 9.50's.
I removed the entire ABS unit, re-routing the brakelines off the master cylinder. All the wiring was also removed from the EBCU. All the wiring was also removed to the wheel speed sensors, shocks and magnasteer. We've narrowed it down that the ASR is alive in the Fly-by wire brain, even though we've cut off the leggs and arms. It is only a problem if you have your foot on the brake, and a brake signal is being sent, then a power brake produces the "bog" (scan shows timing spikes down to ZERO). If you use the line lock (foot off the brake) everything is Ok. I know this is probably something that the majority of you aren't familiar with, I was just hoping that someone else had traveled this road. Thanks for your inputs!!!
You might want to try the guys over at Phoenix who do al the prep work on the T-1 cars.
I doubt the traction control torque limiting code in the PCM is doing what you think it is doing. The brake signal goes to the EBCM, the TAC and the lights. The only way the PCM limits torque is if it receives a variable pulse width signal (PWM) from the EBCM. It doesn't limit the torque when the brake pedal is being pushed which produces a constant level signal and is not connected to the PCM at all. It is highly unlikely that a PWM signal will be erroneously generated out of thin air on the PCM's requested torque input line so the problem more than likely rests with some sort of interaction you are having with the TAC module when the brake pedal is being pushed.
There is a connection from the "Stoplamp" Switch to the TAC .... in my 2001 manual in the section "Lighting Systems" there is an electrical schematic called "Exterior Lights Schematics (Stoplamp Switch and CHMSL)" .... look at that .....
Based on Bill Dearborn's post above .....
Circuit 20 (LT BLUE wire) to the TAC module is energized when you step on the brake pedal ........ might want to look into killing that circuit ..... I'm not responsible for "unintended consequences" of defeating this circuit .... GM put it there for a reason ......
