Lug Nut size on a 2001 C5?
Old Dec 21, 2001 | 02:27 PM
RonWhite's Avatar
RonWhite
Default Lug Nut size on a 2001 C5?
Anyone know?
RW :cheers:
Old Dec 21, 2001 | 03:03 PM
racewheel's Avatar
0racewheel
Former Vendor
Default Re: Lug Nut size on a 2001 C5? (RonWhite)
12 x1.5
3/4" hex
Old Dec 21, 2001 | 08:28 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
The nuts are marked 19 mm on them.
Tom
[Modified by TCW, 7:30 PM 12/21/2001]
Old Dec 22, 2001 | 02:32 AM
Sir Sel's Avatar
Sir Sel
19mm's on my 99.
Old Dec 22, 2001 | 08:09 AM
Randy K's Avatar
Randy K
I've tryed both 19 mm and 3/4". I'm pretty sure that every nut and bolt on the newer vettes were intented to be metric, but in the case of the lug nuts I always use the 3/4" it seem to fit tighter.
Old Dec 22, 2001 | 12:53 PM
Richin Chicago's Avatar
Richin Chicago
Anyone know?
RW :cheers:
I believe it is metric but 3/4 works fine. Tighten to 100 ft lbs in an alternating pattern. (Don't tighten one nut after another but skip over to the next one until you have done them all.)
Old Dec 22, 2001 | 10:46 PM
2kbluestreak's Avatar
2kbluestreak
Default Re: Lug Nut size on a 2001 C5? (Richin Chicago)
19 mm is .748 in. and 3/4 in. is .750 in. That's only a differance of .002 in.,
so both wrenches will work fine. :yesnod:
Old Dec 23, 2001 | 04:07 AM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
Default Re: Lug Nut size on a 2001 C5? (2kbluestreak)
now what if you take an 18mm and oversize it to .749 in. :confused: :confused: :D
To Lug Nut size on a 2001 C5?
