Coilover concerns.
Old Jun 9, 2008 | 09:51 PM
Its_Go_Time's Avatar
Its_Go_Time
Default Coilover concerns.
Anyone use coilovers and have the shock absorber bracket bust off because it was not really meant to support the whole car.
Also because the welds are so crappy...two beads on one of my brackets missed completely
Old Jun 10, 2008 | 12:05 AM
lionelhutz's Avatar
lionelhutz
Have you been reading the C6 Z06 failure thread?
It could happen. Anything is possible. If it looks like the welding is questionable then maybe some welding is in order before you install the coilovers.
Peter
Old Jun 10, 2008 | 12:30 AM
kelp's Avatar
kelp
Coilovers, or even independent springs, by design give the enjoyment of a superior ride and performance compared to single axle leaf springs. However, this should be viewed as a NORMAL configuration for a 1975+ sports car. In reexamining the suspension, it appears the modern corvette was clearly not designed for leaf springs. Yet it is remarkable how consumers have simply accepted it. A leaf spring system is economical to produce, and for decades has been a value to the consumer. Decide for yourself.
The Z06/Pfadt coilover accident: Regardless of design, traumatic conditions generally result in breakage, period. I saw the movie by LG and by Pfadt. Anyone who claims there is no damage following driving over a 6 x 6 log is discrediting themselves.
The bad/missing weld condition you relate should be fixed immediately, as it presents a safety hazard in its being a shock mount. This should not have gone unnoticed.
Old Jun 10, 2008 | 09:55 AM
DPG's Avatar
DPG
St. Jude Donor '06
i got tired of that pissing match over at the c6z06 side, so i stopped following it. LG may be trying to take advantage of a situation to benefit themselves and put a competitor down, can you blame them. they see an opportunity and are trying to take it. I just stopped following after that. $20 says that their coilovers would have gone through the mount if not something else too. I know the guy that it happened to as we came down to cruise in together and we both broke down at cruise in and talk on a regular basis. First off, his frame is aluminum, so you can take that for what its worth. we have steel frames. 2nd, i don't care what you say about shock height and what not. but if you run over a 6x6 piece of anything, something has to give. Running over something that large will make any suspension run outta travel real quick. who knows, he could of ripped the control arm off the frame instead of the shock mount. its just what happened. I wouldn't let that deter you from a coil over system.
Old Jun 10, 2008 | 10:25 AM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
however I would look into some more engineering before trying it on an aluminum frame
Old Jun 10, 2008 | 02:15 PM
DPG's Avatar
DPG
St. Jude Donor '06
from what ive been hearing you can get the mounts beefed up if you choose to. i am not sure who would be able to do something like that though
Old Jun 10, 2008 | 02:35 PM
KBlanke's Avatar
KBlanke
It looks as if no one has answered your question yet, as far as I know, the only reported shock tower failure with coilovers seems to be the one they mentioned from the C6Z06 section. God only knows how many sets of coilovers are in use on C5's. I can only tell you about my luck with them. Me and a buddy of mine have a 02 Z06 that we made into a race car, coilovers were the done before our first race, no problems after many run over rumble strips, bumps on the tracks, and evasive maneuvers. We just bought another car to race and coilovers are gonna be one of the first changes made.
Old Jun 10, 2008 | 04:57 PM
Casem1's Avatar
Casem1
LG using this forum to benefit themselves? NEVER!
If this was a serious problem I would think that it would have become apparent many years ago. The C5 has been around for awhile, after all.
I will, wihtout hesitation, install coil overs on a future Corvette. However, the 'weld' issue does interested me and I think I will have a professional do this mod and have them analyze my mounts first (something i hadn't previously considered!)
Old Jun 10, 2008 | 08:05 PM
Just Enough's Avatar
Just Enough
I think they are no longer referred to as coil overs any more. They are now called log overs.
Old Jun 10, 2008 | 08:33 PM
Its_Go_Time
To Coilover concerns.
